Brand new HKS Turbo timer inc Harness
Suprachargedtt
TBH im not sure on how its works, i know that some alarms have problems running Turbo timers but the majority of modern alarms are ok, your best bet is to do a search for your alarm and see if anyone else has had problems, if your still unsure PM me you alarm details and i can ask my local dealer for you.
Boxed Brand new HKS Turbo Timer type 1 with wire harness and instructions, does all the usual turbo timer things...
Can be found on Whifbitz website £115+vat+harness+delivery
Im looking for around £75 please
Thankyou
James
Just to confirm that this is a type 1 that HKS says does the following:
"The HKS Turbo Timer Type-1 offers all the features of the Type-0, PLUS several monitoring and measurement tools. Vehicle speed and RPM can be displayed on the Type-1’s LCD monitor and a speed warning level can be set. A 2 stage RPM warning can also be set and used as a shift light. When a warning level is reached the Type-1’s LCD monitor will switch from blue to red and an audible beep will sound".
Hi mate im after 1 and this sounds like what im after.just wondered how my current alarm would work with this.ie i get out d car,the engine stays running but when i arm the alarm wouldnt the immoboliser kick in and turn it off?
i have a clifford 650 and this would not work with mine, if it helps :)
