DannoSupra Posted October 30, 2006 Share Posted October 30, 2006 5.9Bar of oil pressure 2500rpm, 0Bar Boost, Oil Temp at 90C and 15%Throttle Does that seem normal? Link to comment Share on other sites More sharing options...
RisingSunSupra Posted October 30, 2006 Share Posted October 30, 2006 thats over 80psi, not sure on the pressure side of things but maybe could it be a blocked filter?? High oil pressure is normally only when oil is cold but 90degrees is normal temps. When was the oil/filter last changed?? Link to comment Share on other sites More sharing options...
DannoSupra Posted October 30, 2006 Author Share Posted October 30, 2006 jst changed it couple weeks ago Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 30, 2006 Share Posted October 30, 2006 Where is your pressure take off?? if its in a sandwich plate then it perfectly normal, mine is around 90 psi HOT and will go well over 100psi when the RPM is up. Link to comment Share on other sites More sharing options...
DannoSupra Posted October 30, 2006 Author Share Posted October 30, 2006 Yeah taken off a Sandwitch plate. Got a Toyota Filter on it aswell.... ideal, cheers boys! Link to comment Share on other sites More sharing options...
