nuttynutz Posted April 30, 2004 Share Posted April 30, 2004 all you genius' what are those two thingys? any ideas? excuse the dirtyness, fresh import still no time to clean it. its a 94 NA, sz i think ollie Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted April 30, 2004 Share Posted April 30, 2004 Top one is to do with the climate control I believe, the lower is probably your dodgy j-Spec fog light. Quote Link to comment Share on other sites More sharing options...
nuttynutz Posted April 30, 2004 Author Share Posted April 30, 2004 ahhhh cheers big ears Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted April 30, 2004 Share Posted April 30, 2004 You've seen the pics of me then? Quote Link to comment Share on other sites More sharing options...
nuttynutz Posted April 30, 2004 Author Share Posted April 30, 2004 ermmm nope. so dumbo or spock? Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted April 30, 2004 Share Posted April 30, 2004 ROFL Quote Link to comment Share on other sites More sharing options...
Graham S Posted April 30, 2004 Share Posted April 30, 2004 hey ollie, Just of the top of my head, the switch will probably be for a fog light as i don't think its standard, i have one the same on my uk TT and it was put in by the previous owner for turning an amp on and off!! As for the nob on the top of the dash i can't remember if mine has one as i haven't been in it for ages! but have had a few cars that have something like that for an alarm light ( Nissan 200sx's use a similar thing). But i'm sure someone will be along to tell you exactly what it is!! Graham.. Quote Link to comment Share on other sites More sharing options...
nuttynutz Posted May 1, 2004 Author Share Posted May 1, 2004 Originally posted by Graham S hey ollie, Just of the top of my head, the switch will probably be for a fog light as i don't think its standard, i have one the same on my uk TT and it was put in by the previous owner for turning an amp on and off!! As for the nob on the top of the dash i can't remember if mine has one as i haven't been in it for ages! but have had a few cars that have something like that for an alarm light ( Nissan 200sx's use a similar thing). But i'm sure someone will be along to tell you exactly what it is!! Graham.. hey sup, yea makes sense that its the fog light, as for the nobbily thing above, dont think it be for the alarm, because that was there before i got the supra, and i fitted the alarm in after. (unless it used to have an alarm and i didnt know, then i stupid for buying and fitting another one. so at the moment i will go with bobbeh, and assume its to do with the climate comtrol. Quote Link to comment Share on other sites More sharing options...
Graham S Posted May 1, 2004 Share Posted May 1, 2004 Yeh, after hearing bobbeh's 'climate control' that does seem to be a good one. was just a wild stab in the dark with alarm!! i don't think i've even seen it on mine! Graham.. Quote Link to comment Share on other sites More sharing options...
suprarob Posted May 1, 2004 Share Posted May 1, 2004 Its the solar sensor for the climate control Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted May 1, 2004 Share Posted May 1, 2004 Originally posted by suprarob Its the solar sensor for the climate control Yep, suprarob is correct. According to TMUK, it is a Terrmistor Assembly, and is part number 88790-24150 Ben.. Quote Link to comment Share on other sites More sharing options...
splurge Posted May 1, 2004 Share Posted May 1, 2004 Yep, bottom one is definitely the rear fog light - it's exactly the same switch as mine's got. Top one, as has been said, is a solar sensor. This detects how sunny it is and makes your climate control blow a bit colder when it's bright outside, because people think it's hotter in the car when it's sunny, even though it may not be, and prefer a slightly cooler environment as a result. Quote Link to comment Share on other sites More sharing options...
suprarob Posted May 3, 2004 Share Posted May 3, 2004 splurge when the sun is on your car the car gets hotter. so when the sun is out the car is hotter so the climate cotrol has to work harder so more cool air comes out of the air vents to keep the temperature of the inside of the car constant. hope this helps Quote Link to comment Share on other sites More sharing options...
splurge Posted May 3, 2004 Share Posted May 3, 2004 Thanks. I must admit, though, that I always thought the solar sensor was to counter perceived hotness due to it being sunny. The climate control system itself should cope with any actual changes to the interior temperature just by using the thermostat, surely? If it wants the temperature to drop and it's not dropping, then it just blows harder anyway. Still, you learn something every day. Quote Link to comment Share on other sites More sharing options...
suprarob Posted May 3, 2004 Share Posted May 3, 2004 it helps the air con react quicker to the change in conditions rather than just react to a temperature change so the temperature stays more constant one of the differences of climate control as aposed to a normal thermastat Quote Link to comment Share on other sites More sharing options...
splurge Posted May 4, 2004 Share Posted May 4, 2004 Ah - cool, thanks! Quote Link to comment Share on other sites More sharing options...
Manic Posted May 4, 2004 Share Posted May 4, 2004 Talking of climate control thingamys mine is playing up. Although the gas is topped up and fine it doesnt get cool, several of the air con switches dont work including: rear window de-mister, feet only selector, auto fan, fan off, and some of the lights on fan speed dont work properley, as soon as u turn the heat control one notch it gets hot in otherwords its either normal air temp or hot, thats it. Any ideas, one has been to get a full air con diagnostic which I may have too do but is a 2 day thing and may cost a fair bit. Any other ideas? Apparently its a good system when it works. Matt Quote Link to comment Share on other sites More sharing options...
Manic Posted May 4, 2004 Share Posted May 4, 2004 Oh and if someone knows the answer: Quote Link to comment Share on other sites More sharing options...
suprarob Posted May 4, 2004 Share Posted May 4, 2004 hi manic usual thing with problems try the fuses. see if any have gone I say you look better in that picture than you did on sunday:D Quote Link to comment Share on other sites More sharing options...
Manic Posted May 4, 2004 Share Posted May 4, 2004 Well if I get the reply which solves it then I might just consider plastic surgery ( lots of it mind you:innocent: ) Matt Quote Link to comment Share on other sites More sharing options...
suprarob Posted May 4, 2004 Share Posted May 4, 2004 yep thats more like you:D Quote Link to comment Share on other sites More sharing options...
Manic Posted May 4, 2004 Share Posted May 4, 2004 Took me years to grow me eyebrows like that:D Watch the women SWOON:cool: Matt Quote Link to comment Share on other sites More sharing options...
suprarob Posted May 4, 2004 Share Posted May 4, 2004 I must admit I did prefer the first pic:) Quote Link to comment Share on other sites More sharing options...
Manic Posted May 4, 2004 Share Posted May 4, 2004 Theres some more but I dont think it would be advisable linking to those Matt Quote Link to comment Share on other sites More sharing options...
suprarob Posted May 4, 2004 Share Posted May 4, 2004 sounds good Quote Link to comment Share on other sites More sharing options...
