XERD 6-2-1 Exhaust header for an NA
jim_supra
I have one of these for sale, I bought it a while back but never fitted it. I no longer need this as I am going NA-T!
It is second hand but in good condition, it has only done approx. 3500 miles when it was on previous owners car.
This will add approx. 17bhp and also does away with the first cat.
I am looking for £200.00 plus delivery (should be around £10-£15)
Pics now added, please bear in mind that the discolouration is normal, this will happen on all polished exhaust manifolds after a short while due to the heat going through them.
looks good and it defo ups the power of the old N/A. what are the two holes for and do i need new seals to fit it.
The two holes are for the o2 sensors, the holes take a screw in sensor, whereas the stock sensors are bolt in. Replacement screw in sensors are readily available from motor factors or the oem sensors can be welded in.
It will also come with gaskets where it bolts to the cylinder head
