Wheelbearing and Self Service.
Foz
Hi All,
Im having a slight problem i need help with. Im getting a slight whine at the rear end when i accelerate, and it gets louder the faster you go (a bit like the waltzer!)
Anyhow im sure its just a wheel bearing so does anyone know the part no or where i can get a replacement from for a 94 TT Aerotop at all?
Also i need to change the engine oil and the gearbox oil, can anyone tell me the suggested oil types for the same car please?
Thanks all!
:p
The oil types you will find talked to death in the FAQs and guides just here:
http://www.mkivsupra.net/vbb/showthread.php?t=56684
You'll find lots of other useful stuff in there too :)
The wheel bearing is a kit that costs about £120 and needs a serious press to get the old one out and possibly to fit the new one. So be warned it's not a driveway job. About 2 hours labour tops to get it done at a garage so it's not that bad.
-Ian
Thanks for the info!
Wow, £120 for a wheel bearing, i take it its more than just a wheel bearing you get then? - god i remember when a wheel bearing for my Escort cost just £15 and took 30 mins to change :(
Do you know where i could pick one up from or is it a dealer visit?
Cheers!
Toyota or I think Blueprint. I don't know the part number but have a search and see what you can find :)
You get the bearing and a bunch of seals. The bearing is absolutely massive though, unsuprisingly. You're a long way from Ford Escort land in quality, durability, and alas prices ;)
-Ian
