Aerotop FIX
Castle
ok so i got the courage to try and take apart my roof and tighten the bolts inside which make all the banging:mad: .....
....well i chickened out when i got half of the sticky rubber crap off (the bit that's meant to be non reusable)
Shall i get some new sticky rubber crap before trting again or just reuse it??
oh and i'm getting quite a bit of drip coming in from the join on the driver's side in the front corner - any fix for this??
Thanks:thumbs:
my advice would be to get new ones but maybe someone else has a better idea as i am not THAT tech minded mate. i saw the problem starting on mine so replaced the rubbers in their entirety but i suppose a good glue should do (unless glue hardens the rubber that is ..).
