Best Engine Oil????
SUPRA FLY
  • Replies 50
Yep thats why am slighty :blonde: ish about it all.
I topped up the oil the other day and put half a litre of Shell Helix Plus which is semi-synthetic because the Helix Ultra (more suittable for performance engines and recommended by Ferrari) which is fully synthetic says its for engines less than 10 years old.....not sure of the difference :blink:
Originally posted by dangerous brain
Well halfrauds are doing buy 1 get 1 free on their own make 5W/40 fully synthetic motor oil if thats any interest to you. I bought some at £29.99 for 2 five litre containers which I am going to use to drain and flush my new TT donk when I finally get it Hint Hint Neil lol:p
Bollocks to that - its just had a 400 quid service :eek: :(
Every fluid changed :(
Arse.
Arse.
Yeah but any good engineer will tell ya when ya hump an dump an generally maul an engine or gearbox you release all sorts of crap that was stuck in allsorts of places into said component (you can't tell I used to work in an early failure detection unit can ya lol) and that standard practice post engine/transmission change is to drain and flush and replace All filters (we used to then send them for analysis including an oil sample lookin at PPM parts per million of metals suspended in the oil) So for the sake of £30 I will whack 2 cans of fully sythentic oil through the blighter over the tuning runs. Bear in mind post chinook helicopter aft transmision change we run it for approx 20 minutes on the ground and empty the oil out and refill at 125 litres of £2 a litre oil then run it for 20 more minutes and do it again, Oh and again between 5 and 25 flying hours.
Fooking hell mate - its only a car piston engine :eek: :p :D LMAO!
Is that how you stopped the failures? BTW is FADEC working properly these days, I've not heard of anything bad for a while?
Originally posted by Timwildman
Someone from the other side, phoned castrol up and asked them.
Tim are you in regular contact with the other side? its just that i've got old relatives i'd like to catch up with.........
er to stay on the techie side, what would make an oil ok for the NA supra but not the TT? I know the turbo's etc can give the oil a harder time and hence more regular changes but i've never heard of a oil being ok for NA's but not TT's........
