Miguel Posted October 29, 2006 Share Posted October 29, 2006 Right so a J-spec is MAP right? So in the least it would need a MAF? Now I can see why it would run lean if it was putting in 0.8 bar of fuel but there was equivlent of 1.2 bar of air in there. The fog is lifting You got it bud. A MAF sensor is calibrated for it injector size and the coresponding airflow. A MAF would still get maxed out if left stock. Link to comment Share on other sites More sharing options...
csa Posted October 29, 2006 Author Share Posted October 29, 2006 Having a turbo of that size and only using it @.7 bar is just a total waste of a turbo. But what's you oppinion...would it harm the engine to run like this? Link to comment Share on other sites More sharing options...
Miguel Posted October 29, 2006 Share Posted October 29, 2006 But what's you oppinion...would it harm the engine to run like this? How long is a piece of string. I don't know the history of this car or how it has been driven. For all I know it might be perfect and has never seen WOT when driven. I would not personaly drive the car without the fueling and ecu in place. The engine could very well be perfect and you could drive it for the rest of your life like it just never going WOT. Just doest make any sense to me why someone would bolt this turbo on and leave everything else stock. That's like Paying for a girlfriends boob job and never getting to play with them Link to comment Share on other sites More sharing options...
imi Posted October 29, 2006 Share Posted October 29, 2006 Good Thread..... So is it true that by using a FPR one can get their 440s to act as 550 for additional fuelling requirement for bigger / single turbos? Is this the way to go, or would one recommend changing for larger injectors? What works out cheaper and what sort of numbers are we looking at in the form of cost? Link to comment Share on other sites More sharing options...
csa Posted October 29, 2006 Author Share Posted October 29, 2006 Just got some pictures of the engine bay. That intake tube look a bit thin i think By the way,what the heck is a "Blitz ID Unit" (look at the last picture, just left of the steering wheel http://img330.imageshack.us/img330/4636/dcam0061yd0.jpg http://img330.imageshack.us/img330/659/dcam0062kx0.jpg http://img330.imageshack.us/img330/395/dcam0063qe6.jpg http://img330.imageshack.us/img330/8219/dcam0064gl9.jpg http://img330.imageshack.us/img330/1928/dcam0056kz0.jpg http://img411.imageshack.us/img411/111/dcam0055kp9.jpg Link to comment Share on other sites More sharing options...
Jake Posted October 29, 2006 Share Posted October 29, 2006 what the heck is a "Blitz ID Unit" It's a boost controller. Link to comment Share on other sites More sharing options...
csa Posted October 29, 2006 Author Share Posted October 29, 2006 been loking around...I'm quite sure it's a "Power meter": http://www.nolimitmotorsport.com/blitz/rmonitor-powerid.html and not the SBC-ID Link to comment Share on other sites More sharing options...
Jake Posted October 29, 2006 Share Posted October 29, 2006 Yeah, you're right - sorry. Link to comment Share on other sites More sharing options...
Gamer Posted October 29, 2006 Share Posted October 29, 2006 Just got some pictures of the engine bay. That intake tube look a bit thin i think By the way,what the heck is a "Blitz ID Unit" (look at the last picture, just left of the steering wheel [qimg]http://img330.imageshack.us/img330/4636/dcam0061yd0.jpg[/qimg] [qimg]http://img330.imageshack.us/img330/659/dcam0062kx0.jpg[/qimg] [qimg]http://img330.imageshack.us/img330/395/dcam0063qe6.jpg[/qimg] [qimg]http://img330.imageshack.us/img330/8219/dcam0064gl9.jpg[/qimg] [qimg]http://img330.imageshack.us/img330/1928/dcam0056kz0.jpg[/qimg] [qimg]http://img411.imageshack.us/img411/111/dcam0055kp9.jpg[/qimg] I think the simple answer to your question of why no boost controller and ECU is that the seller most likely already had a BC and ECU installed on the car and decided not to sell them with the car maybe ? Might be worthwhile to ask him if this was the case and if so what ECU did he use and was it fully mapped or a half finished project ? Link to comment Share on other sites More sharing options...
csa Posted October 29, 2006 Author Share Posted October 29, 2006 allready asked this, and the car has never had a BC or ECU Link to comment Share on other sites More sharing options...
imi Posted October 29, 2006 Share Posted October 29, 2006 CSA - I'd personally stay well clear of this car without knowing more about its mods (or like Gamer says, mods that might no longer be on sale with the car). Link to comment Share on other sites More sharing options...
Alex Posted October 30, 2006 Share Posted October 30, 2006 Doesn't look like a GT42 to me... A GT42 should have a 4-5" intake to start with...and it's upto a 1000hp turbo depending on spec....I call BS. As for the rest of this thread looks like someone has gotten a right hard over nothing. Look the rule of thumb is 1cc = 1hp...but being sensible I knocked 20bhp off as a safety margin. This is at the crank. If you think you can get more than 420BHP on stock 440cc injectors (at the crank) I'd say you were smoking something, which ever turbo you have. Assuming stock rail pressure. And you'll never get to 420bhp on stock ceramic turbo's because they will produce sooo much extra heat and be sooo far outside of their efficiency island that they will just blow the car up if you were to attempt it. Link to comment Share on other sites More sharing options...
Guest dee_rz Posted October 30, 2006 Share Posted October 30, 2006 Doesn't look like a GT42 to me... A GT42 should have a 4-5" intake to start with...and it's upto a 1000hp turbo depending on spec....I call BS. As for the rest of this thread looks like someone has gotten a right hard over nothing. Look the rule of thumb is 1cc = 1hp...but being sensible I knocked 20bhp off as a safety margin. This is at the crank. If you think you can get more than 420BHP on stock 440cc injectors (at the crank) I'd say you were smoking something, which ever turbo you have. Assuming stock rail pressure. And you'll never get to 420bhp on stock ceramic turbo's because they will produce sooo much extra heat and be sooo far outside of their efficiency island that they will just blow the car up if you were to attempt it. agreed with all that and especially about the turbo it looks no bigger than my garratt gt40-88 and i've seen 42's and there huge it would be closer to touching the side of the chassis wall near the struts, the lettering on the turbo that says garratt looks dodgy too not real garratt i.e cheap copy etc Link to comment Share on other sites More sharing options...
Alex Posted October 30, 2006 Share Posted October 30, 2006 Could it be one of these mickey mouse TurboXS GT45's? Link to comment Share on other sites More sharing options...
Ian C Posted October 30, 2006 Share Posted October 30, 2006 In conclusion: Link to comment Share on other sites More sharing options...
csa Posted October 30, 2006 Author Share Posted October 30, 2006 latest additional info is: 50mm extern wastegate JDM JUN STYLE Turbo suction tube is 3" Charging at 3800rpm full on at 4400rpm with existing racecats on Link to comment Share on other sites More sharing options...
Alex Posted October 30, 2006 Share Posted October 30, 2006 It's a lovely looking supra...but without a compression/leakdown test and a dyno sheet I wouldn't have it unless you're willing to pay for the a full rebuild on top...as we suspect it could be running massively lean. Investigate it more but keep your sensible hat on. Link to comment Share on other sites More sharing options...
Miguel Posted October 30, 2006 Share Posted October 30, 2006 That defo does not look like the GT42 I know http://to4r.com/media/gweaver_03.jpg Link to comment Share on other sites More sharing options...
csa Posted October 30, 2006 Author Share Posted October 30, 2006 after all I've decieded not to buy the beast...too many unknown factors. I'm now on the hunt for a good manual TT to convert myself Link to comment Share on other sites More sharing options...
Alex Posted October 30, 2006 Share Posted October 30, 2006 Wise choice. Link to comment Share on other sites More sharing options...
