csa Posted October 27, 2006 Share Posted October 27, 2006 Hi guys I really need som quick advices here Been looking af this baby: http://www.traderamotor.com/showObject.aspx__id~374585__hl~toyota_mkiv_singelturbo It has a GT42 singleturbo conversion but no BC or ECU installed. Is that drivable at all? What will I get if I just install a BC, is that possible or du I have to get a new ECU (AEM or HKS ect) Link to comment Share on other sites More sharing options...
D3xt3r Posted October 27, 2006 Share Posted October 27, 2006 Personally I would stay away from a car that runs a turbo as big as a GT42 with no fueling or ECU mods. That just cries for running lean as hell. Link to comment Share on other sites More sharing options...
toyotatom Posted October 27, 2006 Share Posted October 27, 2006 Wouldnt touch it. Even the most ill prepared and looked after cars out there have at least a boost controller. Link to comment Share on other sites More sharing options...
csa Posted October 27, 2006 Author Share Posted October 27, 2006 what happens to the car when running a setup like this without a BC...will it harm the engine internals or? Link to comment Share on other sites More sharing options...
D3xt3r Posted October 27, 2006 Share Posted October 27, 2006 Boost Controller doesnt matter as it relys on the spring in the wastegate. Depends on what spring is installed there. Link to comment Share on other sites More sharing options...
csa Posted October 27, 2006 Author Share Posted October 27, 2006 I'm a little noob on this aera...can you please explain how it is connected to this spring? Link to comment Share on other sites More sharing options...
D3xt3r Posted October 27, 2006 Share Posted October 27, 2006 There is a spring in the internal wastegate and depending on how stiff that spring is it will allow a certain boost pressure before the wastegate opens and lets exhaust gas through it to keep the turbo from reaching more boost. The stiffer the spring the more boost it will run as a minimum. Link to comment Share on other sites More sharing options...
toyotatom Posted October 27, 2006 Share Posted October 27, 2006 D3xt3r said: Boost Controller doesnt matter as it relys on the spring in the wastegate. Depends on what spring is installed there. Agreed, just makes me wonder if they leave this out what else has been overlooked. Link to comment Share on other sites More sharing options...
csa Posted October 27, 2006 Author Share Posted October 27, 2006 okay I get it thanks! the car has been running this setup for approx one year but only 3000 miles, so would it be to late to "save" it and install the missing parts? Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 27, 2006 Share Posted October 27, 2006 There is no problem running purely off wastegate at all. As long as the spring is correctly selected so that the car can't achieve more boost than is safe on your pump fuels octane rating it's not an issue. I would worry about running a turbo the size of a GT42 without a decent ECU though. Link to comment Share on other sites More sharing options...
csa Posted October 27, 2006 Author Share Posted October 27, 2006 Terry S said: There is no problem running purely off wastegate at all. As long as the spring is correctly selected so that the car can't achieve more boost than is safe on your pump fuels octane rating it's not an issue. I would worry about running a turbo the size of a GT42 without a decent ECU though. why would you "worry" ....because of the wg issue? Link to comment Share on other sites More sharing options...
Clarkey Posted October 27, 2006 Share Posted October 27, 2006 csa said: why would you "worry" ....because of the wg issue? He isn't saying he's worried about the WG spring. What he's saying is - as long as it's fitted properly and limits the amount of boost for the current fueling setup of the car. Link to comment Share on other sites More sharing options...
Alex Posted October 27, 2006 Share Posted October 27, 2006 Looks great though Link to comment Share on other sites More sharing options...
csa Posted October 27, 2006 Author Share Posted October 27, 2006 what should be the estimated output with the current setup? Link to comment Share on other sites More sharing options...
D3xt3r Posted October 27, 2006 Share Posted October 27, 2006 Hard to say why not ask the dude for a dyno print? And also ask him why he stopped 30% into the job. As just fitting a single isnt a big thing the ECU, Fuel and all stuff is really important or the car wont be really fun. Link to comment Share on other sites More sharing options...
Darren Posted October 27, 2006 Share Posted October 27, 2006 Maybe the car is fully sorted just all the details are not in the add? People buy big singles in Japananese auctions without getting the details first... Link to comment Share on other sites More sharing options...
Alex Posted October 27, 2006 Share Posted October 27, 2006 If it's only got 440cc injectors it's limited to about 420BHP. Link to comment Share on other sites More sharing options...
Ian C Posted October 27, 2006 Share Posted October 27, 2006 And it's midrange will be very poor/lean. -Ian Link to comment Share on other sites More sharing options...
csa Posted October 28, 2006 Author Share Posted October 28, 2006 the car is running 0.7 bar limited by racecats and the WG spring at the moment. I'm seriously thinking of bying it, install 700cc's, a good fuelpump, a good BC and a decat DP ...whay do you guys think of this...would't it run okay then? I know I'm not using the capacity of the charger at all, but that's not too important for me...500hp would be more than plenty for me. Link to comment Share on other sites More sharing options...
dangerous brain Posted October 28, 2006 Share Posted October 28, 2006 Alex said: If it's only got 440cc injectors it's limited to about 420BHP. Says who??????? Mine was running 440's and had 395 at the hubs so to say a car can only run 420 brake on 440's is complete bollox chap. The injectors will of course be running pretty much 100% cycle at max chat which I accept isn't the best situation in the world but is possible. Link to comment Share on other sites More sharing options...
Clarkey Posted October 28, 2006 Share Posted October 28, 2006 dangerous brain said: The injectors will of course be running pretty much 100% cycle Which could be possibly Alex's point in the first place! A single turbo - will always shift alot more volume of air than stockers. So, a T61 a 1 Bar .. and a stock tubbies at 1 bar. Which one (stockers or T61) do you think is going to eat the duty cycle the most ? Hmmm ? Link to comment Share on other sites More sharing options...
D3xt3r Posted October 28, 2006 Share Posted October 28, 2006 csa said: the car is running 0.7 bar limited by racecats and the WG spring at the moment. I'm seriously thinking of bying it, install 700cc's, a good fuelpump, a good BC and a decat DP ...whay do you guys think of this...would't it run okay then? I know I'm not using the capacity of the charger at all, but that's not too important for me...500hp would be more than plenty for me. Dont forget something to control the stuff. So throw in a extra 3000€ for AEM and mapping. But still a car like that just calls for troubles. If somebody does this much mods its just behind my mind why he goes cheap on fuel and ecu. As those two points are the most vital parts for reliability. Link to comment Share on other sites More sharing options...
Homer Posted October 28, 2006 Share Posted October 28, 2006 DB, was your car dyno'd at Thor by any chance? As you should be aware by now they are rather well known over inflated HP figures (To say the least...) There's just no way 440cc injectors can flow the sort of figures their dyno has provided, suggest you learn a little more before knocking other people down Link to comment Share on other sites More sharing options...
Clarkey Posted October 28, 2006 Share Posted October 28, 2006 Homer said: suggest you learn a little more before knocking other people down Link to comment Share on other sites More sharing options...
dangerous brain Posted October 28, 2006 Share Posted October 28, 2006 Homer said: DB, was your car dyno'd at Thor by any chance? As you should be aware by now they are rather well known over inflated HP figures (To say the least...) There's just no way 440cc injectors can flow the sort of figures their dyno has provided, suggest you learn a little more before knocking other people down Actually you know what it was dyno'd at thor and for all the related shit the machine produced 395 at the hubs (the 474 they estimated at the fly may have been excessive but you cant argue with the hub figure on a calibrated dyno). That figure was corroborated by sticking it on a seperate rolling road that pushed 375 at the wheels on a considerably warmer day. I also drove the car against other cars with supposed similar power with very good results. Dude before his incarceration was very impressed with its power. So in short there actually is a way that 440's can flow those figures because it did. Suck it up dude not every machine behaves as you expect. I'd also like to point out that the original statement I responded to was If it's only got 440cc injectors it's limited to about 420BHP. which is completely not true. If you wanna be really picky the accepted rule of thumb is a cc for bhp is the limit ie 440cc injectors will support 440 bhp Link to comment Share on other sites More sharing options...
