downimpact Posted October 27, 2006 Share Posted October 27, 2006 This is an easy question but one i can't find if i search. I need to tighten up on of the nuts on my spoiler as it's a little loose and letting rain in This is accessed by taking off the plastic panelling on the boot lid. But how do you get the dam thing off I would have thought it just pulls off? But i've tried quite a bit of force and it doesn't want to come off and i'm wary of breaking plastic lugs. Any help? Cheers J Link to comment Share on other sites More sharing options...
SteveL Posted October 27, 2006 Share Posted October 27, 2006 Your right... it just takes a bit of will power and guts to pull the panel off. Make sure that where you are pulling is not flexing much - that way you know you are near a fixing. Theres a load along the front so you can start there and work your way round. Link to comment Share on other sites More sharing options...
Max Headroom Posted October 27, 2006 Share Posted October 27, 2006 I got my plastic panel off by using a loong handled wooden spoon, starting from the bottom near the rear windscreen slowly edge the wooden spoon in next to the clip and whilst levering it give it a sharp tug. It will take a little bit of punishment and once you have the first couple off its easy. !! Link to comment Share on other sites More sharing options...
_Rob_ Posted October 27, 2006 Share Posted October 27, 2006 once one lug is out, you can get your hand in there and pull the rest out quite easily. with fingers next to the lug, a good sharp push away from the boot lid gets em out. Link to comment Share on other sites More sharing options...
