garetheves Posted October 25, 2006 Share Posted October 25, 2006 As above really. Car was in the garage today sorting out my missfire and i hung around for a while. While i was there they checked the ECU for faults and told me i had a Toms ECU fitted instead of the factory one. Ive heard of them before but never read any reports. Are they any good?? Whats the advantage over stock, if any?? Quote Link to comment Share on other sites More sharing options...
aido Posted October 25, 2006 Share Posted October 25, 2006 One of the Aristo guys I know has one of these, basically think it's a more aggressive map and also doesn't need an SLD as it's delimited as standard on the TOMS version. To quote off his website http://www.lexusvertex.com: Removes boost limit (more boost, more hp), fuel cut and speed limiter. Also allows rev range to 8000rpm. Boost and fuel maps have to be programmed by laptop. ECU in engine bay, very easy install. They're expensive so you're lucky to have one as standard! Quote Link to comment Share on other sites More sharing options...
RedM Posted October 25, 2006 Share Posted October 25, 2006 Have you asked Tom is it's any good? Does he even know you have it? Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 25, 2006 Author Share Posted October 25, 2006 Have you asked Tom is it's any good? Does he even know you have it? You know i nearly put in my first post, "And no jokes about whether Tom wants it back etc etc" because i just knew either you or Michael would make a joke. lol. Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 25, 2006 Author Share Posted October 25, 2006 One of the Aristo guys I know has one of these, basically think it's a more aggressive map and also doesn't need an SLD as it's delimited as standard on the TOMS version. To quote off his website http://www.lexusvertex.com: They're expensive so you're lucky to have one as standard! Cool. So even if its not a massive bonus i suppose its a fairly good selling point, should i ever sell. Sounds impressive lol. Quote Link to comment Share on other sites More sharing options...
Nic Posted October 26, 2006 Share Posted October 26, 2006 I road (seat of the pants) tested a TOMS T.E.C.II ecu a few years ago when my car was relatively stock, it made a noticeable performance difference compared to the stock ecu ie. more responsive and pulled harder. http://www.tomsracing.co.jp/e/product/engine_tec2.htm Quote Link to comment Share on other sites More sharing options...
Class One Posted October 26, 2006 Share Posted October 26, 2006 IIRC they also have a higher fuel cut threshold. Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted October 26, 2006 Share Posted October 26, 2006 Nic how much will one of these little bad boys set you back....might be ab option for budget single guys if you can control fuelling etc with it Quote Link to comment Share on other sites More sharing options...
mawby Posted October 26, 2006 Share Posted October 26, 2006 I had one of these. Here is some background information on it. When I enquired about it when I first discovered I had one I was told that they cost ~£1000 and were sold on an exchange basis, so that's why previously modified import cars which have been returned to stock still have them in as the owner no longer has the original ECU. That's going back a few years now though. Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 26, 2006 Author Share Posted October 26, 2006 Cheers for the replies guys. I like hidden surprises (of the nice kind anyway) in my Supra. Reminds me of when i found a hidden Turbo Timer behind the dash in my old one. Ive also head that no one over here can re-map them, is this correct? Quote Link to comment Share on other sites More sharing options...
mawby Posted October 26, 2006 Share Posted October 26, 2006 They are not re-mapable, at least mine wasn't. It is simply a modified stock ECU. Quote Link to comment Share on other sites More sharing options...
garetheves Posted October 26, 2006 Author Share Posted October 26, 2006 They are not re-mapable, at least mine wasn't. It is simply a modified stock ECU. Cool. Ill add it to my spec list anyway. Wonder if its got any other hidden treats. Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted October 26, 2006 Share Posted October 26, 2006 Is the only whay to find out if you have a modified ECU by toms by opening the ECU cover? Cos apprantly mine has one but it has the stock ECU cover? Quote Link to comment Share on other sites More sharing options...
mawby Posted October 26, 2006 Share Posted October 26, 2006 Nope, it is written on the outside of the ECU. Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted October 26, 2006 Share Posted October 26, 2006 ok cool, - just having a look at the toms website, i find japaneese to english conversions funny here is a bit of it... "The first-class brakes system which controls speed of a heavyweight division high performance car surely. It is completed by joint development with British ap racing company that It adopt in a racing machine. It called and did scrupulous consideration for an unpleasant dirt, and, not to mention splendid effectiveness and feeling, it was developed brakes. Ultimate brakes system was completed here". Quote Link to comment Share on other sites More sharing options...
CardiffSupra Posted October 26, 2006 Share Posted October 26, 2006 I'v got a Toms ECU in mine, Its quite worrieing TBH. I'v only just found out the car used to have a fmic but its been put back to stock when imported, makes you think what else has it had done and what condition the turbos are in if they have been running high boost for a long while. Quote Link to comment Share on other sites More sharing options...
nfsjoe Posted October 26, 2006 Share Posted October 26, 2006 I had one of these. Here is some background information on it. Its mine now though Quote Link to comment Share on other sites More sharing options...
mawby Posted October 26, 2006 Share Posted October 26, 2006 Its mine now though lol..... oh that ban button looks soooo tempting right now! Quote Link to comment Share on other sites More sharing options...
hadyn Posted September 4, 2008 Share Posted September 4, 2008 Sorry for bumping up this thread, but can you run a manual tt toms ecu in an auto tt? Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted September 4, 2008 Share Posted September 4, 2008 would have thought so....it woud need to control your shifts and wouldn't be programmed into the manual one Quote Link to comment Share on other sites More sharing options...
hadyn Posted September 4, 2008 Share Posted September 4, 2008 Isnt there a seperate ecu to control the auto shifts? Quote Link to comment Share on other sites More sharing options...
