Homer Posted October 24, 2006 Share Posted October 24, 2006 I know it relates to the internal diameter of hoses and fitments, but how do you translate imperial measurements to these? I had assumed it was: 4/16 inch = -4 8/16 inch = -8 etc but that doesn't seem correct. Quote Link to comment Share on other sites More sharing options...
Marty Posted October 24, 2006 Share Posted October 24, 2006 im interested in this too, ive had some right fun trying to find a brass 45' fitting with a -10an thread type. Its an american type, i belive the european equivilant is JIC Quote Link to comment Share on other sites More sharing options...
Homer Posted October 24, 2006 Author Share Posted October 24, 2006 I had the same trouble mate - spoke to the guys at think Automotive and they sorted it out right away. Actually spent nearly £180 on aerquip fittings and pipes with them yesterday, but didn't want to ask for them to explain the fitting thing... Quote Link to comment Share on other sites More sharing options...
Bob Posted October 24, 2006 Share Posted October 24, 2006 Here ya go: http://www.mkivsupra.net/vbb/showthread.php?t=86302 Quote Link to comment Share on other sites More sharing options...
SimonB Posted October 24, 2006 Share Posted October 24, 2006 I know it relates to the internal diameter of hoses and fitments, but how do you translate imperial measurements to these? I had assumed it was: 4/16 inch = -4 8/16 inch = -8 etc but that doesn't seem correct. That's right for JIC connections, they are named after the size of hose they fit, so -8 is 8/16th or 1/2inch ID. There are several types of thread and fitting, JIC is a parallel (i.e. not tapered) thread that seals with a cone shaped seat - this means you have to use a special dowty seal (washer with a rubber bit) if you screw one into a hole in something. Then there's BSP, which is the British parallel thread - basically the same as JIC but a different thread pitch so they won't connect up. They are named after the ID of the hose they fit, so you get 1/2BSP for example. Then you have NPTF which is a tapered thread that seals by using PTFE tape and tightning it up - the threads deform slightly when you tighten them. NPTF is measured in 1/2inch etc too, and you can use a 1/2NPTF male with a 1/2BSP female (not the other way round though). Those are the main ones, although you also get metric, which are given as something like M12x1.5, where that's the diameter of the male thread and 1.5 is the pitch. There's also a japanese standard NPT which is slightly different to NPTF, and theres a British standard taper thread as well but you don't get those often. Quote Link to comment Share on other sites More sharing options...
Gordon F Posted October 24, 2006 Share Posted October 24, 2006 A bit more info here Quote Link to comment Share on other sites More sharing options...
Homer Posted October 24, 2006 Author Share Posted October 24, 2006 Many thanks guys, seems its not as easy as I thought Got some reading to do now! Quote Link to comment Share on other sites More sharing options...
LeeT Posted October 24, 2006 Share Posted October 24, 2006 Many thanks guys, seems its not as easy as I thought Got some reading to do now! You could have just asked me;) Quote Link to comment Share on other sites More sharing options...
