Guest mk47 Posted October 23, 2006 Share Posted October 23, 2006 im using dreamweaver and if i insert 2 pictures next to each other, it will only let me do 2 spaces between them, and the same for text anyone know why that is or how to have a bigger space between 2 pics? i want to have pictures to represent links, but the pics are too close to each other and looks Sh1t. cheers Quote Link to comment Share on other sites More sharing options...
Darren-K Posted October 23, 2006 Share Posted October 23, 2006 hya mate, way to do it is like this,. im assuming in dreamweaver before you add any content like pics etc you are creating ( inserting) a table,. the table should have a box for each piece of content ( content being pic, link etc )- and also 1 box for each space between content.. then the space between each pic ( table) can have its width set in the pop up box below in the lower left of the screen. there should be a properties box displaying width and height of each table,. just set the space to desired width etc and this will create the desired space Quote Link to comment Share on other sites More sharing options...
Marco Posted October 23, 2006 Share Posted October 23, 2006 Been years since I've used that. Don't know about the pictures, but for the text, SHIFT+RETURN in stead of RETURN Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted October 23, 2006 Share Posted October 23, 2006 hya mate, way to do it is like this,. im assuming in dreamweaver before you add any content like pics etc you are creating ( inserting) a table,. the table should have a box for each piece of content ( content being pic, link etc )- and also 1 box for each space between content.. then the space between each pic ( table) can have its width set in the pop up box below in the lower left of the screen. there should be a properties box displaying width and height of each table,. just set the space to desired width etc and this will create the desired space Ah Darren cheers mate! that seems to do the job just fine thanks alot Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted October 23, 2006 Share Posted October 23, 2006 Been years since I've used that. Don't know about the pictures, but for the text, SHIFT+RETURN in stead of RETURN hey marco just tried that now but shift + enter takes me a line down, do you have any idea how to add more than 2 spaces between text.. i.e: my - - - name is maz. etc? on there i can only press space bar twice and no more Quote Link to comment Share on other sites More sharing options...
colsoop Posted October 23, 2006 Share Posted October 23, 2006 As said above go to the layout tab then click on draw layout table, within that table you add the layout cells, this is where i put my thumbnail pictures. Quote Link to comment Share on other sites More sharing options...
Darren-K Posted October 23, 2006 Share Posted October 23, 2006 also mk47 try experimenting with some examples on this page, thing about tables is that they will work much better with all browsers, if you allready know the below i apologise in advance http://www.pageresource.com/html/table1.htm Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted October 23, 2006 Share Posted October 23, 2006 thanks for that darren didnt have that info but definately will come in handy! Quote Link to comment Share on other sites More sharing options...
Darren-K Posted October 23, 2006 Share Posted October 23, 2006 np i often copy and paste the exampls in then edit to suit etc i built this website using tables and html via dreamweaver,. nice one mk47 http://www.trancecreator.com Quote Link to comment Share on other sites More sharing options...
edd_t Posted October 23, 2006 Share Posted October 23, 2006 yup tables is the way to go. the space problem you have is a commin thing. afaik all things like dreamweaver and frontpage will remove and double spacing you try and insert. Quote Link to comment Share on other sites More sharing options...
Ric Posted October 23, 2006 Share Posted October 23, 2006 tableless design and CSS structuring is the way forward Quote Link to comment Share on other sites More sharing options...
Darren-K Posted October 23, 2006 Share Posted October 23, 2006 tableless design and CSS structuring is the way forward that would be in an ideal world carbonangel but for example firefox doesnt recognise quite a lot of css ,. also tables are an accepted format for all browsers. Quote Link to comment Share on other sites More sharing options...
n00b Posted October 23, 2006 Share Posted October 23, 2006 tableless design and CSS structuring is the way forward yep that .... you could always put this in the code view picture1.jpg picture2.jpg that would pad the second picture 50 picels to the right of the first picture. or you code totally cheat and do this picture1.jpg [color=Red][b] [/b][/color] picture2.jpg   is a non breaking space and will push it over.... i wouldnt suggest doing it this way. shout if you need a hand Charlie Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted October 23, 2006 Share Posted October 23, 2006 thanks alot guys for all the input really appreciate it! darren good to hear from you again mate hope your doing well Quote Link to comment Share on other sites More sharing options...
