Guest luke1983 Posted April 27, 2004 Share Posted April 27, 2004 Hi all, i have got a 1994 supra, but it was stolen two weeks ago but then i got it back with some small problems. but then i left the lights on so the battery went dead so i got the jump leads to jump start it, but like a fool i i put them on the wrong way round on the other car and then blow the 120amp fuse and some other fuses, so i ordered a new 120 amp fuse from toyota and replaced it but now when i turn the car on all the dashboard lights come on nice and bright like normal but when i turn my car lights on my bashboard lights dim like normal but my speedo lights dont even come on and the thing that tells me what miles i have done just goes off please please help me. luke Link to comment Share on other sites More sharing options...
Supra ST Myster Posted April 27, 2004 Share Posted April 27, 2004 you checked the fuses down by the drivers feet? Link to comment Share on other sites More sharing options...
Guest luke1983 Posted April 27, 2004 Share Posted April 27, 2004 I have just read somethig, can the dimmer switch stop the speedo lights from coming on because if so i dont even have the dashboard on because if this is correct then i feel like a fool. Link to comment Share on other sites More sharing options...
Supra ST Myster Posted April 27, 2004 Share Posted April 27, 2004 the dimmer switch will turn the lights behind that gauge cluster to look like they are off Link to comment Share on other sites More sharing options...
Guest luke1983 Posted April 27, 2004 Share Posted April 27, 2004 i do not even have the dimmer switch attached is this my problem and would it also stop the thing that tells you the miles you have down from coming on. Link to comment Share on other sites More sharing options...
Lewis Posted April 27, 2004 Share Posted April 27, 2004 take it to an auto-electrician Link to comment Share on other sites More sharing options...
Supra ST Myster Posted April 27, 2004 Share Posted April 27, 2004 why do you not have it attached? pretty sure this is your problem! where abouts are you? Link to comment Share on other sites More sharing options...
Jake Posted April 27, 2004 Share Posted April 27, 2004 Yes that is certainly the problem. I know because I drove my car for two days last week without the RH panel (the one with the dimmer switch) and my Odometer didn't work either. Link to comment Share on other sites More sharing options...
Guest luke1983 Posted April 27, 2004 Share Posted April 27, 2004 i did not have it attached because i had to get to the there was glass every were so i am going to get it leathered soon so i just left it all off. and what is the odometer. Link to comment Share on other sites More sharing options...
Guest luke1983 Posted April 27, 2004 Share Posted April 27, 2004 i live in nuneaton why Link to comment Share on other sites More sharing options...
Supra ST Myster Posted April 27, 2004 Share Posted April 27, 2004 Just wondering if you are near me as i can have a look as i have a spare dimmer control switch. Link to comment Share on other sites More sharing options...
Guest luke1983 Posted April 27, 2004 Share Posted April 27, 2004 i am waiting for my battery to charge so i can test the dimmer switch but thanks anyway. what is the odometer is that the miles you have done. Link to comment Share on other sites More sharing options...
Supra ST Myster Posted April 27, 2004 Share Posted April 27, 2004 yes the odometre is that bit that clocks up the miles. Link to comment Share on other sites More sharing options...
Guest luke1983 Posted April 27, 2004 Share Posted April 27, 2004 thanks for all your help i have sorted it now it was the dimmer. Link to comment Share on other sites More sharing options...
