Pics of the inside of the stock ECU
SimonB
Since someone was after some photos of the circuit boards of the stock ECU in this thread and I happen to have mine sitting here I thought I'd take it to bits and post some. Thought I'd better start a new thread rather than post them on that one in PHRs section.
This is a 6sp ECU (non VVTi).
Guest JMR_AW11
Thanks for that Simon.
Any chance of a close up image of the back of the circuit board with the three square chips on it?
Any chance of a close up of the rear of the wiring plugs?
How difficult are these to open up and get into?
I was thinking of wiring my emanage into the inside of the ECU as apposed to the wiring loom....
I dont fancy your chances there, the pins are stacked and quite tightly spaced. You'd also have to have a hole in the case.
As for how hard to open, its not that bad, just a lot of that very sticky black sealer.
They're a bugger to open arent they! All that sealer.
Simon, have you gone standalone now?
I still have that jack you wanted too ;)
Hi John! Must admit once I'd taken the screws out I couldn't figure out why it wasn't coming apart until I realised it was sealed! Bit of leverage with a screwdriver sorted that ;)
Yeah, I've got a Motec M600 now. It's running really well apart from a bit of smoke on full boost which I haven't got to the bottom of. Think it's the oil seal on my turbo that's leaking a bit. Must come over some time and pick that jack up!
