another toyota legend Glanza
rovervi
Own two right now both modified. Not had any problems in the last 2 years of ownership with either car, both very reliable.
I suppose its like most turbo cars if you push the boost up two far, without the right mods you are running the risk of a blown engine but other than that nothing really springs to mind. Once you up the boost you do tend to push the limits of the stock clutch.
The standard cars should run trouble free. As usual look for crash damage and abuse when buying second hand. Second hand and aftermarket parts are cheap and readilly available.
Kevin
  • 4 weeks later...
