Whitesupraboy2 Posted October 20, 2006 Share Posted October 20, 2006 A light-tight wooden box has three switches on the outside that control three light bulbs on the inside. When the box is closed you can turn the switches on or off but when you open the box how can you tell which switch controls each bulb without touching the switches? 2nd puzzle below: How few times can you weigh 9 identical cookies on a balance scale to find the one with a gold ring inside? Link to comment Share on other sites More sharing options...
Ian W Posted October 20, 2006 Share Posted October 20, 2006 so the light will stay on/off when you open the box but you can only move the switch when it's closed? surely it's a simple process of elimination? Link to comment Share on other sites More sharing options...
Max Headroom Posted October 20, 2006 Share Posted October 20, 2006 Easy turn on switch 1, then open box and whichever is warmer than the other two is operated by that switch, repeat with switch 2 and then whatever is left is switch 3 Link to comment Share on other sites More sharing options...
Jake Posted October 20, 2006 Share Posted October 20, 2006 With box closed change the position of the first switch. Open the box and see if/which light is illuminated. Rinse and repeat Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted October 20, 2006 Author Share Posted October 20, 2006 should of been clearer you can only open the box once! Link to comment Share on other sites More sharing options...
Ian W Posted October 20, 2006 Share Posted October 20, 2006 should of been clearer you can only open the box once! are the lights all off to begin with? Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted October 20, 2006 Author Share Posted October 20, 2006 are the lights all off to begin with? yes Link to comment Share on other sites More sharing options...
Jake Posted October 20, 2006 Share Posted October 20, 2006 should of been clearer you can only open the box once! Link to comment Share on other sites More sharing options...
edd_t Posted October 20, 2006 Share Posted October 20, 2006 easy. get the answer from the same thread a couple of weeks ago teehee... Link to comment Share on other sites More sharing options...
Max Headroom Posted October 20, 2006 Share Posted October 20, 2006 should of been clearer you can only open the box once! Now you tell us!!!!! Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted October 20, 2006 Author Share Posted October 20, 2006 easy. get the answer from the same thread a couple of weeks ago teehee... not a repost ...surely I have one other brain teaser i was sent. Link to comment Share on other sites More sharing options...
Ian W Posted October 20, 2006 Share Posted October 20, 2006 you flick two switches. turn one off after a while then open the box. the light that is on is the first one, warm one (which was on but now off is the second) and the third will be off and cold. voila Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted October 20, 2006 Author Share Posted October 20, 2006 Now you tell us!!!!! Like it makes any difference Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted October 20, 2006 Author Share Posted October 20, 2006 you flick two switches. turn one off after a while then open the box. the light that is on is the first one, warm one (which was on but now off is the second) and the third will be off and cold. voila Can only flick one switch at a time only 1 light can be on. though you are very close. Just need to rearrange your answer before someone nicks it Link to comment Share on other sites More sharing options...
Ian W Posted October 20, 2006 Share Posted October 20, 2006 Can only flick one switch at a time only 1 light can be on. now you're just changing the rules. Link to comment Share on other sites More sharing options...
Jake Posted October 20, 2006 Share Posted October 20, 2006 you flick two switches. turn one off after a while then open the box. the light that is on is the first one, warm one (which was on but now off is the second) and the third will be off and cold. voilaHow will that tell you anything about the third one? Link to comment Share on other sites More sharing options...
Max Headroom Posted October 20, 2006 Share Posted October 20, 2006 Like it makes any difference No not really but thanks anyway:p Link to comment Share on other sites More sharing options...
Jake Posted October 20, 2006 Share Posted October 20, 2006 Can only flick one switch at a time only 1 light can be on. Link to comment Share on other sites More sharing options...
Ian W Posted October 20, 2006 Share Posted October 20, 2006 put one on to warm it up, then switch off. turn another on and open the box. yes? Link to comment Share on other sites More sharing options...
Ian W Posted October 20, 2006 Share Posted October 20, 2006 How will that tell you anything about the third one? three switches, three bulbs. the switch you leave on will have a lit bulb, the switch you had on will be warm and thus the third and last switch will be cold and off? Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted October 20, 2006 Author Share Posted October 20, 2006 put one on to warm it up, then switch off. turn another on and open the box. yes? Correct ok next brain teaser... How few times can you weigh 9 identical cookies on a balance scale to find the one with a gold ring inside? Link to comment Share on other sites More sharing options...
Ian W Posted October 20, 2006 Share Posted October 20, 2006 three. ignore that, my head hurts. Link to comment Share on other sites More sharing options...
Max Headroom Posted October 20, 2006 Share Posted October 20, 2006 So my answer was correct then wsb2 !! Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted October 20, 2006 Author Share Posted October 20, 2006 So my answer was correct then wsb2 !! No you opened the box twice Link to comment Share on other sites More sharing options...
Max Headroom Posted October 20, 2006 Share Posted October 20, 2006 Once Link to comment Share on other sites More sharing options...
