rick001 Posted October 20, 2006 Share Posted October 20, 2006 Under braking my steering wheel and pedal judder - what is the issue ? Quote Link to comment Share on other sites More sharing options...
ardasaliah Posted October 20, 2006 Share Posted October 20, 2006 Warped Brake Disc- a new set will sort it Quote Link to comment Share on other sites More sharing options...
Pig Posted October 20, 2006 Share Posted October 20, 2006 But if your like me your will just warp the next set! oops! Quote Link to comment Share on other sites More sharing options...
Scooter Posted October 20, 2006 Share Posted October 20, 2006 Under braking my steering wheel and pedal judder - what is the issue ? if you have the smaller j-spec brakes it may be a seized sliding (now not sliding!) pin........... Quote Link to comment Share on other sites More sharing options...
Nic Posted October 20, 2006 Share Posted October 20, 2006 It could be disks, but it could also be a knackered wheel bearing. Jack the car up and see if there is any side to side play on each of the wheels, if there is any movement then you'll need a new bearing. The nearside ones tend to go first, as the wheels on this side are prone to being curbed. Quote Link to comment Share on other sites More sharing options...
TRD3000GT Posted October 20, 2006 Share Posted October 20, 2006 Either the HUB or the disk.. The bearing would make the wheel judder all the time. NOT just under breaking. By the way, your new here so try out the search at the top right hand side.. This has been asked MANY times Quote Link to comment Share on other sites More sharing options...
Nic Posted October 20, 2006 Share Posted October 20, 2006 The bearing would make the wheel judder all the time. NOT just under breaking. Not necessarily true, when mine went I could only feel it under braking. Quote Link to comment Share on other sites More sharing options...
Nic Posted October 20, 2006 Share Posted October 20, 2006 Similar symptom here, turned out to be the wheel bearing: http://www.mkivsupra.net/vbb/showthread.php?t=81769 Quote Link to comment Share on other sites More sharing options...
