Front hubs and Bearings
suprattgaz
After replacing discs twice in 3 months decided to get run out on my front hubs cheked yesterday due to bad braking wobble. Both measured at 0.1mm..... out of spec!!! SO need both near and off side hubs and bearings for front of '94 Jspec TT.
Toyota quoted £100 x 4!!!
Is the £100 for hub and bearing?
The front wheel bearings should a lot cheaper than the rears, I can do the following prices, but order time from Japan would be around 4 weeks.
90369-43005 Rear Wheel Bearing = £65 each + postage
90903-63006 Front Wheel Bearing = £32 each + postage
