SupraStar 3000 Posted October 19, 2006 Share Posted October 19, 2006 Electric Ganador Mirrors installation. This weekend I want to fit Nic’s Ganador Mirrors but the instructions are in japanese and for something that I imagined to be relatively easy to DIY the instructions seem very complex Haven’t really studied them yet but in anticipation of problems, has anyone installed them and have any tips / info they can share. Thanks Link to comment Share on other sites More sharing options...
Gaz Walker Posted October 19, 2006 Share Posted October 19, 2006 Actually really easy Ed, you might want to give Kev a call as he fitted his. See, we didn't even supply them and still happy to give advice Gaz. Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted October 19, 2006 Author Share Posted October 19, 2006 Thanks Gaz, much appreciated mate I like the sound of "really easy" Link to comment Share on other sites More sharing options...
supRo Posted October 19, 2006 Share Posted October 19, 2006 Ed - Straight swap mate! 1, remove door card 2, There will be holes/access area on the inner door skin where you can access the mirror mount bolts (2) 3, Undo the two bolts and diconnect the wiring connector 4, You may find a little rust around the mirror mounts on the door - treat that if necessary 5, Do the above steps in reverse order to fit the Ganador mirrors - I think the Ganador come with their own bolts so use those two instead but DO NOT OVERTIGHTEN as they snap easily! The electrical connector is exactly the same as stock so just push that back in. The Ganador sit higher than the stock mirors, on the corner with the door and front of the door glass. They tend not to sit flush with the door pillar so you may want to get sticky foam strips to pad it up. Pic of Ganador mirrors on my car: http://www.mkivsupra.net/vbb/vbpicgallery.php?do=big&p=3435 Cheers, Ro Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted October 19, 2006 Author Share Posted October 19, 2006 Ro, Your an absolute legend Thank you. exactly what I wanted. Link to comment Share on other sites More sharing options...
supRo Posted October 19, 2006 Share Posted October 19, 2006 No worries Ed. As you know the Supra mirror mounts are notorious for holding water - You wash your car and it's still dripping water from the mounts 2 hours later! Hence you may find a little rust around the mount hole on the door. Cheers, Ro Link to comment Share on other sites More sharing options...
Nic Posted October 19, 2006 Share Posted October 19, 2006 Good luck Ed, as said the mirrors are easy to fit. If you've not removed the door cards before here is a how to guide courtesy or Heckler. http://www.internetwork.org.uk/Dash%20Conversion/doorrem.htm Link to comment Share on other sites More sharing options...
Pete Posted October 19, 2006 Share Posted October 19, 2006 As you know the Supra mirror mounts are notorious for holding water - You wash your car and it's still dripping water from the mounts 2 hours later! So it's the mounts is it? That really REALLY annoys me. I might look at sealing this better one day. Link to comment Share on other sites More sharing options...
Gazzawu Posted October 19, 2006 Share Posted October 19, 2006 this site is brilliant! great find http://www.internetwork.org.uk/Dash%20Conversion/doorrem.htm Link to comment Share on other sites More sharing options...
Nic Posted October 19, 2006 Share Posted October 19, 2006 this site is brilliant! great find http://www.internetwork.org.uk/Dash%20Conversion/doorrem.htm The site is Heckler's (Si) member on here, it contains lots of handy how to guides. http://www.internetwork.org.uk/supra.htm Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted October 19, 2006 Author Share Posted October 19, 2006 Thanks guys! Removed the door cards a few times for speaker upgrades so that shouldn't be a problem Cheers Nic, Ill take some pics soon as its done Link to comment Share on other sites More sharing options...
