Guest Vangsoe Posted October 19, 2006 Share Posted October 19, 2006 Hi guys, 1994 MKIV NA. Rev counter is acting up at around 3,000 rpm. Jerks forth and back like 1,000 rpm. Below 3,000 and above 4,000 there are no probs. Any ideas ? Tks mates Niels Quote Link to comment Share on other sites More sharing options...
Alex Posted October 19, 2006 Share Posted October 19, 2006 Auto or Manual? Could it be the clutch or torque converter on their way's out? If it's neither of them you'll have to check the wiring, to see if it's faulty. Quote Link to comment Share on other sites More sharing options...
Jake Posted October 19, 2006 Share Posted October 19, 2006 Check for a bad earth or faulty DSC/TSD Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted October 19, 2006 Share Posted October 19, 2006 I have this problem sometimes, also when the speedo is jecking up and down it cuts the power steering?? After a few seconds goes back to normal... i have a HKS SLD, maybe it's this causing it to happen if its faulty? Quote Link to comment Share on other sites More sharing options...
JustGav Posted October 19, 2006 Share Posted October 19, 2006 When you say rev counter is jumping... Do you mean the needle is jumping or is the engine revving oddly as well.. Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted October 19, 2006 Share Posted October 19, 2006 When you say rev counter is jumping... Do you mean the needle is jumping or is the engine revving oddly as well.. Just the speedo needle for me... thats why I think its somthing electrical (SLD) ? Quote Link to comment Share on other sites More sharing options...
johnnyknox Posted October 20, 2006 Share Posted October 20, 2006 I might get shot down here... I'm new to Supra's but intend to get one soon. I had a 1995 STI Impreze with this same problem. Turned out to just be the cable for the rev counter. If it gets bent in any way, it then kind of acts like a skipping rope inside its housing. As it rubs against it's housing it causes the needle to skip. You could either remove the cable, grease it up and pop it back in, or get a new cable. Like I say, may be wrong. Quote Link to comment Share on other sites More sharing options...
JustGav Posted October 20, 2006 Share Posted October 20, 2006 It isn't mechnical on a supra... Sounds to me like the delimiter or something is acting up... Quote Link to comment Share on other sites More sharing options...
Pixelfill Posted October 20, 2006 Share Posted October 20, 2006 mine did this, right before the car died completely, and wouldn't start - I jumped out head under the bonnet, and the Negative lead had come off the battery post, so as Jake says check your earths. Mike Quote Link to comment Share on other sites More sharing options...
