Simon K Posted October 19, 2006 Share Posted October 19, 2006 Hi all, Been a member for a while, tend to use search button alot, but cant find answer for my brake servo issue. I have a rz tt facelift, with smaller jap brakes. Ive recently changed the brake pads / fuild. All bleed properly, but the pedal doesnt feel as rigid as it once was. Got a sneaky idea its the master brake servo. So, how do you test a master brake cylinder ?? Should the car be running or off ? is it a case of pressing down hard, and the pedal staying put, or should it slowly sink down ? Any tips would be gratefully recieved. Are the size / pressures of the servo's, on a smaller brake car, the same size of a standard uk - bigger brake car ? Anyone know of anybody selling a very low mileage master brake servo for a mkiv rz tt auto ?? SBK Quote Link to comment Share on other sites More sharing options...
Alex Posted October 19, 2006 Share Posted October 19, 2006 Bigger calipers take more fluid ot fill/move them. If the Mastercylinder is passing the same amount of fluid as stock then it will take a longer pedal travel to apply the brakes. If the pedal goes hard after being pumped once then everything is ok. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted October 19, 2006 Share Posted October 19, 2006 Did you push fluid back up from brake to master as i was told never to do this as it can damage seals in master . Not much help but thought would mention it !! Quote Link to comment Share on other sites More sharing options...
