Ian C Posted September 20, 2006 Share Posted September 20, 2006 The MkIV Supra autobox is considered by many to be an excellent auto gearbox, and one of the best most have ever driven. It has an Overdrive button and a MANU (manual mode) button, and these are the source of much confusion and urban mytherry. Here below is the function of these buttons and how the autobox responds, according to years of experience of several owners Normal Mode (Overdrive ON, MANU OFF) Selecting L will give you 1st gear only Selecting 2 will give you 1st and 2nd gear, with normal shift logic applied Selecting D will give you 1st, 2nd, 3rd, and 4th gear (overdrive), with normal shift logic applied MANU Mode (Overdrive ON, MANU ON) Selecting L will give you 1st gear only Selecting 2 will give you 2nd gear only Selecting D will give you 2nd and 3rd gears only. The box will attempt to stay in 3rd most of the time, but it is possible to kickdown into 2nd if your speed is below 70-75mph. The box will also select 2nd gear if you come to a crawl/stop, and will reselect 3rd using the normal change logic, but the gear changes will be that bit quicker (see below). Overdrive has no effect in MANU mode, you'll never get beyond 3rd gear unless you hit the redline, at which point it changes up into overdrive to protect the engine and gearbox. If you engage MANU whilst is overdrive then it will not immediately change down, but waits until there is a need to change down following normal change logic. If you are going faster than 3rd gear can deliver then it will never change down until your speed drops to something deliverable by that gear. This stands, in fact, for any manual gear selection - it won't happen unless the resultant gearchange drops the revs within the available rev range. Banging it into L at 100mph will merely result in an electronic sneer from the box. (Park and Reverse are different matters...) MANU makes the transitions between gears faster. The ECTS throttle system cuts back on the throttle during gearchanges, and in MANU mode it cuts back less, therefore making the shifts harsher but losing a bit less acceleration during the gearchange. MANU mode does not "hold the gear longer" as it holds the gear indefinitely anyway - it shifts when you make it shift. The exception is when the stick is in D, as described above - the shifting pattern will still follow normal logic, i.e. it depends on throttle position, engine load, and revs as to when it changes gear. Overdrive Off Mode Selecting L will give you 1st gear only Selecting 2 will give you 1st and 2nd gear, with normal shift logic applied Selecting D will give you 1st, 2nd, and 3rd gear, with normal shift logic applied It will not change gear any faster and will not "stay in gear longer" just because overdrive is off. The autobox will already wind up to the redline if you are at wide open throttle, it knows you want power, that's why it's an 'auto' - you don't need manual intervention from the driver to persuade it to stay in gear. Also of note - the gearbox may come out of MANU mode and overdrive Off mode if the gearbox is risking damage by staying in them (i.e. it's overheating). Thanks to Mawby, Class One and Soop Dogg for their technical input to this -Ian Link to comment Share on other sites More sharing options...
sparkyspar Posted June 26, 2007 Share Posted June 26, 2007 wow anutha question answered before i asked it.cool: Link to comment Share on other sites More sharing options...
s3upra Posted June 26, 2007 Share Posted June 26, 2007 Great info-easy to understand,but you realise people will still ask q's without using the "magic,scary search button!" Oh and what does the RED button do? Link to comment Share on other sites More sharing options...
ultra_supra Posted June 27, 2007 Share Posted June 27, 2007 out of curiosity - do most auto box drivers drive with overdrive off or on? only i usually always drive with it off but when i take it to places lke turbo fit (for example) they always put overdrive on.... jus wondered Link to comment Share on other sites More sharing options...
Mike Posted June 27, 2007 Share Posted June 27, 2007 On all the time (save money on fuel in a higher gear), but take it off when I pull on a motorway.... the boy racer I am! Link to comment Share on other sites More sharing options...
AndyT Posted June 27, 2007 Share Posted June 27, 2007 So how the cack do the tuners dyno an auto.???? Link to comment Share on other sites More sharing options...
Class One Posted June 27, 2007 Share Posted June 27, 2007 Manu mode in D closest gear for a 1:1 on the auto There's a thread about how to dyno by Alex somewhere Link to comment Share on other sites More sharing options...
Ian C Posted June 28, 2007 Author Share Posted June 28, 2007 Manu mode in D closest gear for a 1:1 on the auto There's a thread about how to dyno by Alex somewhere It's pinned at the top of tech -Ian Link to comment Share on other sites More sharing options...
dangerous brain Posted July 5, 2007 Share Posted July 5, 2007 Have to disagree here both my supra's in manu mode would select 4th gear ie overdrive when you push the o/d button in and out and would lock it in 4th until the revs dropped too low for the engine to sustain itself. My aristo which is setup on a mk4 supra aem with manu mode does exactly the same thing. Link to comment Share on other sites More sharing options...
Guest munchie Posted July 11, 2007 Share Posted July 11, 2007 so if you were going to attempt a 1/4 mile drag how would you use the box? Link to comment Share on other sites More sharing options...
Class One Posted July 11, 2007 Share Posted July 11, 2007 so if you were going to attempt a 1/4 mile drag how would you use the box? Do a search on power braking. Link to comment Share on other sites More sharing options...
dangerous brain Posted July 11, 2007 Share Posted July 11, 2007 And then fit an auto box cooler Link to comment Share on other sites More sharing options...
Guest challabrat Posted July 18, 2007 Share Posted July 18, 2007 Oh and what does the RED button do? Yes... what DOES the red button do? Link to comment Share on other sites More sharing options...
dangerous brain Posted July 18, 2007 Share Posted July 18, 2007 Man I do not believe I am saying this but use the search button. Its been covered a million times (thats an exaggeration) Basically it allows you to remove the ignition key in gears other than park on J-spec cars. Link to comment Share on other sites More sharing options...
Guest vipprotuning Posted August 9, 2007 Share Posted August 9, 2007 cheers for the info:D Link to comment Share on other sites More sharing options...
ivan Posted August 9, 2007 Share Posted August 9, 2007 Man I do not believe I am saying this but use the search button. Its been covered a million times (thats an exaggeration) Basically it allows you to remove the ignition key in gears other than park on J-spec cars.It also allows you to move the lever out of Park without putting the key in. Link to comment Share on other sites More sharing options...
supraGZaerotop Posted May 26, 2008 Share Posted May 26, 2008 hello i have tt auto, this part in your thread, OverDrive/OFF It will not change gear any faster and will not "stay in gear longer" just because overdrive is off. The autobox will already wind up to the redline if you are at wide open throttle, it knows you want power, that's why it's an 'auto' - you don't need manual intervention from the driver to persuade it to stay in gear. so if it does not change any quicker and goes the same then whats the point in having the O/D button Link to comment Share on other sites More sharing options...
mawby Posted May 26, 2008 Share Posted May 26, 2008 The OD button will stop the auto box using the 4th gear, which if you're doing some spirited driving through twisty roads is useful as it prevents the auto box constantly changing between 3rd and 4th. Link to comment Share on other sites More sharing options...
supraGZaerotop Posted May 26, 2008 Share Posted May 26, 2008 ok so its there just to give alittle more engine control then, ive tryed it once or twice switching OD off and carnt say ive noticed any difference, was driving normally tho. people on here say if you want to go and give it the beans then pop it out of OD, but as stated in previous thread it goes the same anyway, so its there to provide more engine control/ or engine braking yes Link to comment Share on other sites More sharing options...
tichkent Posted May 26, 2008 Share Posted May 26, 2008 I nearly always switch the OD off when driving fun roads - it kicks down to second much faster from third than it does from fourth, and just feels much sportier with the revs a little higher (particularly in an NA where the power doesn't really kick in till 5k). Actually I often switch OD off when I'm in a 30/40 zone as well coz it annoys me when it's constantly switching between third and fourth! Probably not the best for petrol usage tho... Link to comment Share on other sites More sharing options...
DSK Posted April 1, 2009 Share Posted April 1, 2009 excellent easy to follow information for a newbie, thank you. Link to comment Share on other sites More sharing options...
clarky666 Posted May 7, 2009 Share Posted May 7, 2009 Thanks for this. I had more than a few gripes and worries before going to pick up an automatic tomorrow (never driven one before) but this puts my mind at ease slightly. Am i right in saying for first time driving and getting used to the car, gently, that i should go with over drive on in D untill i get to grips with it ? Link to comment Share on other sites More sharing options...
gordy07 Posted May 7, 2009 Share Posted May 7, 2009 (edited) Welcome Edited May 7, 2009 by gordy07 (see edit history) Link to comment Share on other sites More sharing options...
gordy07 Posted May 7, 2009 Share Posted May 7, 2009 Yes clarky leave it in D until you get the hang of it,with OD on it is more economical to use 4 gears. And take it easy,especially if its wet. Link to comment Share on other sites More sharing options...
Todd Posted May 7, 2009 Share Posted May 7, 2009 And take it easy,especially if its wet. He's an old MR2 owner, well used to driving like a nun in the wet Link to comment Share on other sites More sharing options...
