Spoiler Down/ AUTO
boombastictiger
They're pulling your leg ;)
If you have the button this means you most likely have an active front spoiler fitted - do you still have the stock front bumper?
The front spoiler deploys at 60mph (I think), the Auto-Off button stops the spoiler from deploying.
The 'Down' button deploys the spoiler manually but this can only be done with the engine off and the ignition on '2'.
If its flashing then you have a fault, either the spoiler has been removed or its getting stuck. (either of which should result in big error light on tach)
Yet I have an aftermarket spoiler...the person i bought it from changed it..ahhh that would be cool to have a active spoiler..
:Pling:
when you say you have an aftermarket spoiler, i immediately think the rear of the car.
this active spoiler is on the front below the plastic rubber lip.
ya its an aftermarket front spoiler...Man..I wonder what affects the active spoiler would of had..
off the top of my head slightly greater stability when cornering at high speed.
i wouldn't worry about it too much mate, most people like it just for the look :cool:
Flashing active spoiler light means your car is about to explode, get out and run!!!!!1!
yes,,, quick,,, run whilst throwing women and children behind you in order to protect you from the blast :p
At least you now have a switch already fitted that you can use for something else!
this is also true
