RedM Posted October 17, 2006 Share Posted October 17, 2006 *Serious responses only please* After using our electric shower we are getting a fishy smell from just outside the bathroom door, roughly above the meter, fuse box etc. Having had a quick search on the net would I be right in thinking that this smell is a sign that something is overheating or burning? There are no visible signs and we've only had the smell since the weekend. The shop below report nothing out of the ordinary either. Cheers. Link to comment Share on other sites More sharing options...
garetheves Posted October 17, 2006 Share Posted October 17, 2006 *Serious responses only please* After using our electric shower we are getting a fishy smell from just outside the bathroom door, roughly above the meter, fuse box etc. Must.....Resist.... Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted October 17, 2006 Share Posted October 17, 2006 Must.....Resist.... Have you sniffed around the head and box unit? Does it smell fishy? Link to comment Share on other sites More sharing options...
Thorin Posted October 17, 2006 Share Posted October 17, 2006 It'll be the... *Serious responses only please* Never mind. Link to comment Share on other sites More sharing options...
absz Posted October 17, 2006 Share Posted October 17, 2006 i was having the same problem it was the trip thats melting away in the fuse box with the load of the electric shower i had to do away with the 30amp trip and fit a separate fuse box with a 45amp trip to cure it. Link to comment Share on other sites More sharing options...
michael Posted October 17, 2006 Share Posted October 17, 2006 Call Landlord - let them worry about it. Sit back and laugh as they get the bill for the rewire. Link to comment Share on other sites More sharing options...
RedM Posted October 17, 2006 Author Share Posted October 17, 2006 i was having the same problem it was the trip thats melting away in the fuse box with the load of the electric shower i had to do away with the 30amp trip and fit a separate fuse box with a 45amp trip to cure it. So, baths until it's fixed then! Call Landlord - let them worry about it. Sit back and laugh as they get the bill for the rewire. Done. Link to comment Share on other sites More sharing options...
jamesmark Posted October 17, 2006 Share Posted October 17, 2006 Martin, a fishy smell is serious, is it beside the meter? If so its what is called "Pitch" its a balck rubber substance that is inside the meter and this is melting, this should be treated as an emergancy mate you should call Yorkshire electricity straight away. Link to comment Share on other sites More sharing options...
michael Posted October 17, 2006 Share Posted October 17, 2006 Done. Ah the joys of renting Link to comment Share on other sites More sharing options...
jamesmark Posted October 17, 2006 Share Posted October 17, 2006 If its the meter there is sod all the Landlord can do, lets hope its the fuse box. Link to comment Share on other sites More sharing options...
RedM Posted October 17, 2006 Author Share Posted October 17, 2006 The meter and fuse box are situated in the shop downstairs. The shop people have smelt nothing. The smell 'area' in our flat is not directly above the meter but it is very close to a large isolator switch thing situated on the wall in our bedroom. Directly through the wall is the shower. We have had issues with this switch before so fingers crossed. Grittish Bass are coming out to have a look tomorrow and until they've been and fixed it then it'll be baths (gas boiler heated) or au naturel!!!! Oh, and cheers for texting me Mark. While it was mych appreciated it also freaked me out a little during my working day when I couldn't do a thing about it. Grrrr.... Link to comment Share on other sites More sharing options...
Pete Posted October 17, 2006 Share Posted October 17, 2006 Does the fishy smell go once you've had a wash? Link to comment Share on other sites More sharing options...
RedM Posted October 17, 2006 Author Share Posted October 17, 2006 Does the fishy smell go once you've had a wash? *Serious responses only please* Link to comment Share on other sites More sharing options...
Charlotte Posted October 17, 2006 Share Posted October 17, 2006 When did you get serious? Or are you taking the piss out of yourself? Link to comment Share on other sites More sharing options...
milocoon Posted October 17, 2006 Share Posted October 17, 2006 Could be a burn`t out or damaged power supply wire supplying the shower, from memory 2 types of cable can be used (6mm if the distance from consumer box to shower is less than 3 metres or 10mm if its more than 3 metres, 10 mm is dearer than 6mm so a few budget conscious "rogue leccies" choose the "correct type" ) How far away from the shower is the "fishy smell" ? If its rented insist on immediate repairs as the smell may be toxic ! Link to comment Share on other sites More sharing options...
Pabs Posted October 17, 2006 Share Posted October 17, 2006 i installed a replacement electric shower this weekend... 9.5kw needs a 45amp fuse, 8.5kw can get away with a 40amp. (according to the paperwork we got with the shower) I've say that you need it sorted pronto - the only thing that should smell is YOU (at least before you get in the shower) Oh, and the cabling might not be in fantastic shape - if this is a new shower, chances are the power of the replacement shower are too high for the size of cabling used. Link to comment Share on other sites More sharing options...
Shaun. Posted October 17, 2006 Share Posted October 17, 2006 Does the fishy smell go once you've had a wash? Hoorah ! Nice one Jake .. lets get this thread back to "normal" Shaun. Link to comment Share on other sites More sharing options...
Jake Posted October 17, 2006 Share Posted October 17, 2006 Does the fishy smell go once you've had a wash? Hoorah ! Nice one Jake huh? Not all the crap jokes on here are by me you know Shaun! Link to comment Share on other sites More sharing options...
michael Posted October 17, 2006 Share Posted October 17, 2006 huh? Not all the crap jokes on here are by me you know Shaun! LOL, you tell him Pete Link to comment Share on other sites More sharing options...
Pete Posted October 17, 2006 Share Posted October 17, 2006 huh? Not all the crap jokes on here are by me you know Shaun! LOL, you tell him Pete Link to comment Share on other sites More sharing options...
