De-Cat fitting
Paul R
Hi,
I need a CW de-cat pipe fitting. Chris is busy at the moment and cant get my car on his ramps to do it.
I've got an FCD already and I'll fit that tonight.
Can anyone recommend a trusted and experienced garage in the N/W or midlands that could fit the pipe??
Otherwise I'll just wait til Chris is free!
Cheers,
Paul.
Come and do it for me then mate :D
I dont fancy doing it with the car on axle stands in the road! I havent got the luxury of a garage or anything.
The can be a PITA anyway if the bolts have seized and there wouldnt be much room to maneuver to drill them out.
Paul.
Any dodgy backstreet spanner monkey should be capable of doing the decat pipes, if they have stud issues chances are they will also have extraction tools and studs so don't panic :)
Avoid somewhere like Kwik Fit by all means but a general, well established mechanic should be more than capable of doing the work.
And if you need a restrictor ring try using your restrictor foot less heavily on the RH pedal until you get a chance to order one :)
  • 1 month later...
