JamieP Posted October 16, 2006 Share Posted October 16, 2006 Do i need them for HKS 1000cc injectors or do they plug in my stock ones? Many thanks jamie:) Quote Link to comment Share on other sites More sharing options...
Pig Posted October 16, 2006 Share Posted October 16, 2006 Sits quietly waiting for someone to come along with a good one.... Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 16, 2006 Author Share Posted October 16, 2006 May i remind you this is in Technical:p Quote Link to comment Share on other sites More sharing options...
JustGav Posted October 16, 2006 Share Posted October 16, 2006 I would ASSUME that you might need pigtails... however fiveo do a little convertor lead should you require it, that does it, saves hacking the loom up. Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 16, 2006 Author Share Posted October 16, 2006 This is the pic of the injector nic gave me:) Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 16, 2006 Author Share Posted October 16, 2006 Anyone? Quote Link to comment Share on other sites More sharing options...
supradibbs Posted October 16, 2006 Share Posted October 16, 2006 i would also like too know the answer too this before i buy a set Quote Link to comment Share on other sites More sharing options...
Ian C Posted October 16, 2006 Share Posted October 16, 2006 I'd assume yes, you do need pigtails. Injectors bought off the shelf like this are usually one standard fitting, and OEM ones usually are specific to the manufacturer. Expect to have to fit them and I doubt you'd be disappointed. -Ian Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 16, 2006 Author Share Posted October 16, 2006 Thanks ian. Quote Link to comment Share on other sites More sharing options...
JustGav Posted October 17, 2006 Share Posted October 17, 2006 As I mentioned to Jamie, there is an option with converter leads, which means you don't need to hack the factory loom up... http://www.fiveomotorsport.com/Injector_CONNECT.asp Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 17, 2006 Author Share Posted October 17, 2006 All sorted now mate... the injectors i ordered from Nic came with the pigtails;) Quote Link to comment Share on other sites More sharing options...
Voo51 Posted October 17, 2006 Share Posted October 17, 2006 Was going to have such a girly moment then!!! Quote Link to comment Share on other sites More sharing options...
