hob Posted October 16, 2006 Share Posted October 16, 2006 I ordered a second radiator (busted first one) from an ebay guy (100% feedback etc) and it turned up today but its different its not shiny it has a KOYO logo but it's raised and not embossed (as other one) Doesn't have front sprayed racing flag I can take pictures if required, does it sound legit? Link to comment Share on other sites More sharing options...
Thorin Posted October 17, 2006 Share Posted October 17, 2006 Pics? I don't know what a genuine should look like though. Will you be fitting it yourself? I'd be interested to know what the fitment is like compared to the fluidyne, whether you can keep the top air duct etc. too (see http://www.mkivsupra.net/vbb/showthread.php?t=83646&highlight=fluidyne) Link to comment Share on other sites More sharing options...
imi Posted October 17, 2006 Share Posted October 17, 2006 arent there two versions of the rad...one is the OEM placement which is cheaper, the 2nd is the racing version that is more expensive and thicker. Link to comment Share on other sites More sharing options...
psymon Posted October 17, 2006 Share Posted October 17, 2006 I have an shiny oem one, and fitting is the same as stock..... Great fitment and looks the dogs:d Link to comment Share on other sites More sharing options...
Thorin Posted October 17, 2006 Share Posted October 17, 2006 I have an shiny oem one, and fitting is the same as stock..... Great fitment and looks the dogs:d Can you retain the top air duct? Do you have to trim away a little of the fan shroud to fit? Does the secondary fan bolt up fine at all three points? Just curious Link to comment Share on other sites More sharing options...
psymon Posted October 17, 2006 Share Posted October 17, 2006 Can you retain the top air duct? Do you have to trim away a little of the fan shroud to fit? Does the secondary fan bolt up fine at all three points? Just curious Yes you can retain top airduct, but you have to make a small plate bout 25mm and drill 2 holes in it, to secure the bolt that normally screws into the rad. Its further back on the Koyo, think this is due to its thinkness, but very easy to do. Fan shroud is a std fit, no cutting etc nescessary. Secondary fan, std fit no mods required Link to comment Share on other sites More sharing options...
Nic Posted October 17, 2006 Share Posted October 17, 2006 Koyo make 2 models for the JZA80, the Type-R and Type-Z. The Type R is painted the Type Z is polished Alu. I know that there are knock offs of the Koyo radiators made that are sold as genuine. See pics here: http://www.koyorad.co.jp/shop/M1100801.htm Link to comment Share on other sites More sharing options...
Thorin Posted October 17, 2006 Share Posted October 17, 2006 Yes you can retain top airduct, but you have to make a small plate bout 25mm and drill 2 holes in it Pics? Link to comment Share on other sites More sharing options...
hob Posted October 17, 2006 Author Share Posted October 17, 2006 Opened a dispute with paypal: http://www.scribbleproductions.co.uk/stuff/koyo1.jpg http://www.scribbleproductions.co.uk/stuff/koyo2.jpg http://www.scribbleproductions.co.uk/stuff/koyo3.jpg http://www.scribbleproductions.co.uk/stuff/koyo4.jpg http://www.scribbleproductions.co.uk/stuff/koyo5.jpg http://www.scribbleproductions.co.uk/stuff/koyo6.jpg doesn't feel like a genuine koyo, but the quality is spot on lol and it was packaged better too! Link to comment Share on other sites More sharing options...
imi Posted October 17, 2006 Share Posted October 17, 2006 NOPE, certianly not what I received.....you are right to dispute good luck Link to comment Share on other sites More sharing options...
Thorin Posted October 17, 2006 Share Posted October 17, 2006 Ok so nowhere to bolt the top air duct on the Koyo rad either... and it looks like there's one of the holes missing for bolting the secondary fan up too? Link to comment Share on other sites More sharing options...
psymon Posted October 17, 2006 Share Posted October 17, 2006 Mine doesn't look like that, and all things stock went back on. Link to comment Share on other sites More sharing options...
hob Posted October 17, 2006 Author Share Posted October 17, 2006 Mine doesn't look like that, and all things stock went back on. its a celica radiator, but there is a comparison between two that I bought, one I think is real the other fake. Link to comment Share on other sites More sharing options...
hob Posted October 17, 2006 Author Share Posted October 17, 2006 found out it is genuine, but just the "older" one, exactly the same just oxidized a bit. Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted October 17, 2006 Share Posted October 17, 2006 I have the polished version and it bolts straight in, no cutting or modifications required. Link to comment Share on other sites More sharing options...
StuartW Posted July 8, 2009 Share Posted July 8, 2009 Anyone got any contacts or prices to obtain a Koyorad? Link to comment Share on other sites More sharing options...
