Matt H Posted October 15, 2006 Share Posted October 15, 2006 I bought myself some tiger seal yesterday on recommendation to fit my new sills but came into a slight problem when i got home!! lol, i cant get the stuff out of the tube! In a vain attempt to not sound dumb and have to post up help i tried for a good while yesterday trying to work out how in gods name you get the stuff out of the tube but it was no good So, anyone know how this thing works! how does it come out!! Quote Link to comment Share on other sites More sharing options...
Kranz Posted October 15, 2006 Share Posted October 15, 2006 What the fcuk is Tiger Seal??? Sounds like a hybrid sea creature with big teeth! Quote Link to comment Share on other sites More sharing options...
markrzs Posted October 15, 2006 Share Posted October 15, 2006 What the fcuk is Tiger Seal??? Sounds like a hybrid sea creature with big teeth! lol Quote Link to comment Share on other sites More sharing options...
supRo Posted October 15, 2006 Share Posted October 15, 2006 I thought you had to remove the metal plate on the bottom and it has beady stuff in it. Use a screwdriver to punch a hole in the bottom, remove the plate and then use it in a sealant gun. Double check though. I may be talking out of my arse! I have used it before. Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted October 15, 2006 Share Posted October 15, 2006 whats that? a tiger blew a seal? Quote Link to comment Share on other sites More sharing options...
Cable Posted October 15, 2006 Share Posted October 15, 2006 Kinda like sicka flex aint it? Black silicon stuff. I thought you just used a caulk gun? Quote Link to comment Share on other sites More sharing options...
Jake Posted October 15, 2006 Share Posted October 15, 2006 I may be talking out of my arse! I have used it before. Your arse? Quote Link to comment Share on other sites More sharing options...
supRo Posted October 15, 2006 Share Posted October 15, 2006 Your arse? lol! You use a normal sealant cartridge gun. I think the metal plate at the bottom of the cartridge is there to protect it, once removed you use it like a normal sealant/adhesive cartridge Quote Link to comment Share on other sites More sharing options...
jaiscossie Posted October 15, 2006 Share Posted October 15, 2006 if you put the tube in hot water for ten mins to soften it up then cut the top off or put a nozzle on it. it should then squeeze out easily. this stuff is great when gone off. so so strong!! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 15, 2006 Share Posted October 15, 2006 Kinda like sicka flex aint it? Black silicon stuff. I thought you just used a caulk gun? Sicka flex is far better, if your using it to fill gaps Tiger seal will crack! Quote Link to comment Share on other sites More sharing options...
Matt H Posted October 15, 2006 Author Share Posted October 15, 2006 o....m...... fucking........G Just managed to get this crap out of the tube and stuff it on the skirts, after a bit it dawns on me, this crap isnt an adhesive, its that f*ckin water resistant sealent tar used for sticking around the plastic sheeting in your doors.... bloody hell, i cant believe someone on here actually recommened using this as a glue!!!!!!!!!!!!!!!!!!!! dont know whether to laugh or cry, it never goes off for one thing!!!!!!!!!!!!!!!! And the worse thing is, it gets f*cking everywhere, Some people are just so stupid!! why would you ever use this product for sticking something down. Cant believe i got so far into the job before i realised what i had just done! Gonna get some super glue like i originally intended now, before i thought there was a magical product out there called tiger shit. Quote Link to comment Share on other sites More sharing options...
Matt H Posted October 15, 2006 Author Share Posted October 15, 2006 P.s you have probably gathered how pissed off i am! i'll be chilled out again tommorrow though, hopefully Quote Link to comment Share on other sites More sharing options...
LeeT Posted October 15, 2006 Share Posted October 15, 2006 you have bought the wrong stuff then. Tigerseal is just the brand name. you need tigerseal pu adhesive Quote Link to comment Share on other sites More sharing options...
Matt H Posted October 15, 2006 Author Share Posted October 15, 2006 you have bought the wrong stuff then. Tigerseal is just the brand name. you need tigerseal pu adhesive Yep thats the stuff ive got, PU adhesive sealant, black silicon type tar crap Quote Link to comment Share on other sites More sharing options...
absz Posted October 15, 2006 Share Posted October 15, 2006 tigerseal is great for fitting bodykits and sills:d just give it time to cure Quote Link to comment Share on other sites More sharing options...
absz Posted October 15, 2006 Share Posted October 15, 2006 you have bought the wrong stuff then. Tigerseal is just the brand name. you need tigerseal pu adhesive Quote Link to comment Share on other sites More sharing options...
Matt H Posted October 15, 2006 Author Share Posted October 15, 2006 tigerseal is great for fitting bodykits and sills:d just give it time to cure The new sills arent correctly shaped for the original sills i.e new sills are just sheet metal cut up and the original sills are moulded in a curve so unless your willing to sit there for hours on end pressing it down into a curve then its super glue all the way Quote Link to comment Share on other sites More sharing options...
absz Posted October 15, 2006 Share Posted October 15, 2006 you can always screw it down Quote Link to comment Share on other sites More sharing options...
Matt H Posted October 15, 2006 Author Share Posted October 15, 2006 you can always screw it down umm, may lose the effect that way! Nope, gona slide it off tommorrow (cos it wont be stuck down) and then use super glue. (after removing this tiger shit from my shoes, the patio and the carpet......... :badmood: Quote Link to comment Share on other sites More sharing options...
LeeT Posted October 15, 2006 Share Posted October 15, 2006 umm, may lose the effect that way! Nope, gona slide it off tommorrow (cos it wont be stuck down) and then use super glue. (after removing this tiger shit from my shoes, the patio and the carpet......... :badmood: good luck getting it off, it's a right bugger. Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted October 15, 2006 Share Posted October 15, 2006 white spirit helps a lot (hope you're a non-smoker!!) Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 15, 2006 Share Posted October 15, 2006 Spirit wipe, methes or if your careful 2K thinners, if your fitting any kind of body kit and it doesn't fit right, then build up the kit with fibre glass and then trim it to fit the car, your wasting your time trying to bond it on if you have warped or ill fitting parts, Sikaflex 221 is one of the best for kit fitting, it won't shrink and it can be painted over. Quote Link to comment Share on other sites More sharing options...
