ABS and TRC light
Ray
Easy fix Ray. Pop the following things out. The check engine, ABS, TRAC moduleon the left of the dash, open it up and resolder all the solder joints. Somewhere there is couple of cold solder (cracked solder joints). After that you need to pop the relays on the left of the engine bay for the trac and abs (4 items). Open them up carefully and with a very thin sandpaper clean the realy inside on the lock point. After that 100% everything will be working. I hope I made my self clear. I did this fix at a friend's car when he bought about 2 months ago.
ahhh thanx for the info il try that tommorow :)
regards
