JohnK Posted October 14, 2006 Share Posted October 14, 2006 I need a Southbend DXD clutch for a '95 UK TT. Dual Friction (Kevlar & Metallic 6 puck) Traders please quote me, delivered to my door in Hampshire. Link to comment Share on other sites More sharing options...
JohnK Posted October 21, 2006 Author Share Posted October 21, 2006 Anyone??? Link to comment Share on other sites More sharing options...
Gaz6002 Posted October 25, 2006 Share Posted October 25, 2006 I'm interested in this as well, traders??? Link to comment Share on other sites More sharing options...
SimonB Posted October 25, 2006 Share Posted October 25, 2006 I would recommend AGAINST the sprung hub clutch disk version of this (this is the one you would get if you have a solid lightweight flywheel rather than the stock one). Mine broke with metal fatigue where the springs are mounted after about a year/10000 miles. Looking at it afterwards you could see it was an obvious weak point. Shame because the clutch itself was great. I think the non-sprung one that you would get to go with the stock flywheel should be fine though. Link to comment Share on other sites More sharing options...
Gaz Walker Posted October 25, 2006 Share Posted October 25, 2006 I'm don't normally deal with Southbend... Although I'll see if I can get some prices tommorow Gaz. Link to comment Share on other sites More sharing options...
Gaz6002 Posted October 26, 2006 Share Posted October 26, 2006 I would recommend AGAINST the sprung hub clutch disk version of this (this is the one you would get if you have a solid lightweight flywheel rather than the stock one). Mine broke with metal fatigue where the springs are mounted after about a year/10000 miles. Looking at it afterwards you could see it was an obvious weak point. Shame because the clutch itself was great. I think the non-sprung one that you would get to go with the stock flywheel should be fine though. I read this in a previous post from you mate - I will be going with the non-sprung one. I'm not going to change the flywheel unless it needs changing, i'm under good authority that it does the job quite nicely Link to comment Share on other sites More sharing options...
JohnK Posted October 29, 2006 Author Share Posted October 29, 2006 I'm don't normally deal with Southbend... Although I'll see if I can get some prices tommorow Gaz. Any news on this? Link to comment Share on other sites More sharing options...
Chiefgroover Posted October 29, 2006 Share Posted October 29, 2006 It's surprising how much power a Centerforce dual friction clutch can handle. Andy @ RSE ran big twins, about 600 bhp for 3 years on one (about 60K) held great but he avioded big standing starts. While stuck for a clutch, he gave me his old centerforce, which i did a track day, the ring, almost Austria and back with much hard driving before it started to slip. Felt like stock etc. I'd go with it for sure again, but if your for the 1/4 mile .....nope!. Link to comment Share on other sites More sharing options...
Suprash Posted October 31, 2006 Share Posted October 31, 2006 I have a Southbend clutch and lightened flywheel sat in the garage, not sure whether its the DXD clutch or not, I can try and find out for you if you want....... Clutch has done about 15,000 in total and clutch plate that came out still has some wear left on it....... Link to comment Share on other sites More sharing options...
