Brake cylinder stoppers
toyotatom
I've already told you. If your leg is strong enough to make the bulkhead flex, then yes, it's worth getting! :innocent:
Suppose it all depends on how hard you use the anchors and if you use both feet like me :eyebrows:
I've got a Cusco one and it looks very nice! :D
I noticed quite an improvement in medium to heavy braking when I fitted my Cusco one.
Get someone to press the pedal when parked and see how much the brake master cylinder flexes. The brake master cylinder is different on cars with smaller brakes factory fitted, these can flex a lot if you upgrade to the larger brakes.
I'd definitely recommend fitting one, along with a set of braided lines and good brake fluid. This should really firm up the pedal feel and improve stopping power.
The only noticeable difference we have found is on the track. You do not require it for normal road use.
If I needed to brake in an emergency, I would want any improvement to braking I could get.
They cost less than a set of braided lines and make a similar improvement in pedal feel and stopping power in my experience.
Sorry, I'm new round here.
What is a Brake cylinder stopper?
They brace the brake master cylinder, reducing flex under hard braking. If you can visibly see the brake master cylinder flexing, fitting one of these will help.
There are 2 products that I know of, the Cusco brace and the Carbing Tower Bar with built in brace.
http://img227.imageshack.us/img227/1766/p1020540gg6.jpg
http://img223.imageshack.us/img223/7982/dsc01372smallay5.jpg
It doesn't have any impact on how well the brakes work, the stopper just improves brake feel.
Well, it may give a *BIT* more braking force as you can apply more force to the pedal.
If the bulkhead is flexing then some of the force applied to the pedal goes into the bulkhead, and is not transferred into the brake fluid.
This would occur only during the pressure buildup (transitional force) stage as you are increasing the force on the pedal .
When the pedal force levels out (i.e. you have reached the desired braking force) the bulkhead will stop flexing and the forces will equalise, as for every force, there is an equal (in size) and opposite (in direction) reaction force (Newton's third law) that will 'push' against the force applied by your foot.
You may also want to remove the seat cushions and weld in sheet metal so that when you push against your brakes your body can't flex either, this will help improve the brake feel as well :)
Or get robotic legs like the Million Dollar Man to give more force at the pedal??? :p
