Rear Wheel Bearing Kit
weinelm
This kit contains the bearing, the two oil seals and a split pin. You can re-use the circlip.
As Rob said, if your bearing is really shot the drive flange may be damaged and may need replacing too (this isn't in the kit). I've done a couple of RWBs and the flange was fine on both, but I think I caught them early.
  • 2 weeks later...
