Hello All
Guest banjo_quint
Guest banjo_quint
Hi, just registered so thought I'd better say hello and thanks for the advice from trick152 I found about removing the drivers seat belt, without it I'd have much more broken plastic than I do. Starting to think I should have kept the Capri though!
CJ
get a grip
cau u change your id? feeling offended that you are not my minder again....miss u :)
L
whoooops my typing is shite ....meant can u change your id...!?
Guest banjo_quint
I've had about every Capri there was from the embarrassing 1.3 to the 3.0 GXL, which only ever drove in a straight line after I'd been T-boned on a roundabout. I like to think of myself as something between Bodie and Doyle, but with a more magnificent girth. My MkIV is a bit normal at the moment (I hope that's ok), but I'll sort out some pics and update the profile asap. Good to be here.
