Fibreglass Side skirts
DArby
Got a pair of Firbre Glass side skirts - how the hell do they stay on ??
Considering how flexible they are, i would assume they need fixing every 25mm...
I can see how they fix at the front. Do you remove the existing black plastic that runs along under the door ??
Also i can see the back black plastic within the wheel arch are fixed with some kind of plug - not screwed - how do they come out ??
Dean..
Quote: from DArby on 7:53 pm on Sep. 14, 2001[br]Considering how flexible they are, i would assume they need fixing every 25mm...
Every inch !!......... thats not fiberglass thats Rizlas stuck together........
send 'em back!!:biggrin:
The black plugs just push in ........
Dean....
If you look underneath the sill trim you will find 10mm self tapping screws.
This trim is also held by plastic clips which locate in the sill.
The rear panel,and arch trim again are held by screws and clips
Once you've removed the trim, the original screw points should be enough to hold the skirt.
Darrell
