Decat and lamba sensor
jamesmark
Yes, you need it. Running without it will hurt the MPG and probably make it run in limp home mode as well as other problems.
Is it supposed to be fitted before the first cat on the downpipe? I guess you don't have a boss on the first decat pipe??
Cheers Jake, thats one question answered, now the next. Where can I buy just a flange then to weld on as I have a decat pipe with no 02 flange.
You won't need to mess about with a bung/flange 'cos decatting doesn't affect the Lambda sensor. It's located upstream of the first cat.
No mate just a pipe with the gauze tpe of stuff round it in the middle. No flange, as in downpipe before the first cat, is that on the manifold?
cause if its there then ok then.
Thing is, iirc the lambda sensor is mounted in 'the downpipe' but what Toyota call the downpipe is the cast iron part between the exit of the turbo system and the first cat (or first decat pipe) ...
... whereas a lot of us say 'downpipe' when talking about the first decat pipe.
I think this causes a lot of confusion sometimes.
:shrug:
