miko_supra Posted October 11, 2006 Share Posted October 11, 2006 A friends mk1 punto headgasket went the other day. i have never done a head gasket before. but me and a friend figured we'd give it a shot, as its either that or bin it. so just wondering if anyone has any useful advice or know of a decent web page. Quote Link to comment Share on other sites More sharing options...
miko_supra Posted October 11, 2006 Author Share Posted October 11, 2006 Not to worry, i thought of the obvious and got a haynes manual. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted October 11, 2006 Share Posted October 11, 2006 I've changed a headgasket on a Rover Metro. Not too bad, just familiarise yourself well with the procedure before starting. For example, you don't want to undo the head bolts in the wrong order. If you've got "mayonnaise" in the engine (from mixing oil and water) then when the HG's been changed, run the engine with diesel oil for about 1000 miles to clean it out, then do an oil change as normal. Get the head surface checked for flatness, and get it skimmed if it's warped. When you've bolted the engine back together, whilst the spark plugs are out turn the crankshaft manually using a spanner and make sure it turns relatively smoothly with no untoward resistance. If you've got the timing wrong, you'll hopefully feel the valves impacting the pistons. Better to do it this way, than to crank it using the starter motor and then need to replace all the valves!! Quote Link to comment Share on other sites More sharing options...
