bowk1uk Posted October 10, 2006 Share Posted October 10, 2006 i,m about to install my na-t kit ,stripped the compresser to drill and tap for a pressure fitting , then noticed the compresser had no o ring seal is this ok or is the turbo crap ? if this is crap , can anyone recomend a good turbo to buy for everyday driving, preferably with 3" intake Link to comment Share on other sites More sharing options...
LeeT Posted October 10, 2006 Share Posted October 10, 2006 Turbos don't have an 'o' ring seal where you are suggesting. Looks normal to me Link to comment Share on other sites More sharing options...
bowk1uk Posted October 10, 2006 Author Share Posted October 10, 2006 so how does the compresser housing seal to the back plate ive seen these with o ring seals before Link to comment Share on other sites More sharing options...
LeeT Posted October 10, 2006 Share Posted October 10, 2006 so how does the compresser housing seal to the back plate ive seen these with o ring seals before It just does:D I've got two turbos here which are the same and i've seen plenty of others that do not have the seal you are talking about Link to comment Share on other sites More sharing options...
terribleturner Posted October 10, 2006 Share Posted October 10, 2006 My T66 didn't have an O-Ring there Surely the heat would be too much for a rubber O-Ring. Link to comment Share on other sites More sharing options...
hodge Posted October 10, 2006 Share Posted October 10, 2006 I used to build turbos for a living and they definately dont have a rubber o-ring in there. What type of turbo is it? Link to comment Share on other sites More sharing options...
Kranz Posted October 10, 2006 Share Posted October 10, 2006 The J spec std turbo has an O ring because it doesn't have a mating flange like all the others and this one. Your turbo looks fine mate! If you don't like it I'll have it Link to comment Share on other sites More sharing options...
LeeT Posted October 10, 2006 Share Posted October 10, 2006 I used to build turbos for a living and they definately dont have a rubber o-ring in there. What type of turbo is it? By the size of that Hot side i'm going to say it is the XS-power T60-1 Link to comment Share on other sites More sharing options...
bowk1uk Posted October 10, 2006 Author Share Posted October 10, 2006 its an xs power t57 that came with the kit thanks for info guys,puts my mind at rest here,s to show you i was,nt dreaming,that looks like a seal to me Link to comment Share on other sites More sharing options...
Daston Posted October 10, 2006 Share Posted October 10, 2006 My xs-power T61 has a seal Link to comment Share on other sites More sharing options...
absz Posted October 10, 2006 Share Posted October 10, 2006 the pic in your first post does not require a seal as its a flat machined surface were the housings come together. Link to comment Share on other sites More sharing options...
