SONY AV2100T - Universal Remote Control
Todd
This is a Sony RM-AV2100t tv remote control.
£40 all in, comes in box with manual, screen is unmarked, small scratch to left of program button.
Sonys advertising banter
The Sony RM-AV2100 universal LCD touchscreen remote control is a great way to consolidate up to 12 of your controllers into one. It's completely programmable, easy for all types of users to learn and what's more works great. It's quite flexible and comes with more than enough memory to learn the codes of any A/V equipment that may not already be pre-programmed. Advanced Learning Function for programming remote signals of many non-A/V products such as air conditioners and lights. The beauty of this model is that every button for a particular device is always available, while the labels still change to reflect their new functions. The touchscreen is very responsive, and features the very bright backlight. Physical channel up/down and volume up/down buttons are present, and work regardless of whether the LCD is first enabled or not. You can also copy one remote to another. The RM-AV2100 can be duplicated to - or from - other remotes with the [T] symbol on them. Last but not least, 15 Macro control functions allow a series of up to 16 consecutive operations to be executed by one touch. If you're tired of having seven or more remotes on your coffee table, you should give the RM-AV2100 serious consideration. It could just save you some space!
  • 2 weeks later...
bttt
Still open to offers, even throw in a Sony WR590 double tape deck in great nick (remote work with it as well)
This SONY dual cassette deck features Dolby B, C, NR, Dual 2-motor drive system, Automatic Reverse, Record on deck B only, Record Level and Balance controls, Automatic Tape Selection, A to B dubbing, Digital display, 4-digit digital tape counters, Rec Mute, 3-position DIR mode switch.
example photo, NOT mine
http://homepage.mac.com/justinjoffrion/public2/IMG_3897.jpg
