Ambrose7 Posted April 18, 2004 Share Posted April 18, 2004 Hi guys, driving home from work on friday, i noticed a weird feeling like i had a nail in my tyre, i got out, checked all round and the tyres were fine, good i thought, got home and parked up. then i took it out for a spin yesterday, and it still feels the same, but its getting worse, and it seems to be under breaking more than crusing, it feels like the car is slightly jumping up and down, tested it again today and its now a heavy shuder under breaking, and when driving at a constant speed i can feel it shudering and starting to make a slight grinding noise. can anyone point me in the right direction where to look for problems? getting a bit scared to drive it now! thanks Link to comment Share on other sites More sharing options...
matt Posted April 18, 2004 Share Posted April 18, 2004 Check the wheel nuts............ I assume you checked the tyre pressures , and didn't just look at 'em? Link to comment Share on other sites More sharing options...
Ambrose7 Posted April 18, 2004 Author Share Posted April 18, 2004 the wheels are all on fine, and i checked the pressures, and all is good Link to comment Share on other sites More sharing options...
matt Posted April 18, 2004 Share Posted April 18, 2004 Better jack up each corner and make sure nothing's fallin' off then! Check disc/pads for probs Also check for any stickin calipers, play in bearings, joints etc. Grab the wheel top&bottom check for play Grab the wheel at 3&9 o'clock and check for any play Stick a big bar under the tyre at 6 o'clock and lift up .. look for play in joints Link to comment Share on other sites More sharing options...
LeeT Posted April 18, 2004 Share Posted April 18, 2004 if your car is jumping up and down like you say, i would check the rear shocks. Link to comment Share on other sites More sharing options...
SimonB Posted April 18, 2004 Share Posted April 18, 2004 Well, shudder under braking points to warped discs. I had some on my old Celica that warped so much they were throwing the balance of the wheel off too so you could feel it even when not braking. Or it could be a wheel bearing. Link to comment Share on other sites More sharing options...
