Prof. Monkey Posted October 9, 2006 Share Posted October 9, 2006 Anyone have a diagram of the front crank seal and the associated part number? Thankyou in advance.... Link to comment Share on other sites More sharing options...
Nic Posted October 10, 2006 Share Posted October 10, 2006 See attached. Link to comment Share on other sites More sharing options...
Prof. Monkey Posted October 10, 2006 Author Share Posted October 10, 2006 Thankyou Nic, that has sorted that one, its not that which is leaking, its seems to be a rubber gasket that fit into the corner of the front, just behind the the crank dampener and seems to sandwich between the metal of the engine and the plastic of the cover. Strange! Link to comment Share on other sites More sharing options...
Nic Posted October 10, 2006 Share Posted October 10, 2006 If you point out where, perhaps someone can help. http://www.enginereplacement.com/images/ebay/2jzge_front_sm.jpg Link to comment Share on other sites More sharing options...
Jonny5 Posted October 10, 2006 Share Posted October 10, 2006 sounds like it could be leaking oil from somewhere above and accumulating at the point where you can see it.. Link to comment Share on other sites More sharing options...
mattanna Posted October 10, 2006 Share Posted October 10, 2006 Could be anywhere my aristo had front crank done but still leaked turned out to be a faulty/leaking oil pressure sensor switch which is near aircon somewhere?? Link to comment Share on other sites More sharing options...
Rob Posted October 10, 2006 Share Posted October 10, 2006 Thankyou Nic, that has sorted that one, its not that which is leaking, its seems to be a rubber gasket that fit into the corner of the front, just behind the the crank dampener and seems to sandwich between the metal of the engine and the plastic of the cover. Strange! Trust me, I only had it in pieces a few months ago. The only thing there that will leak oil is the crank seal. Other option is the rocker cover and it's dripping down to there. Link to comment Share on other sites More sharing options...
Prof. Monkey Posted October 10, 2006 Author Share Posted October 10, 2006 Rob, did you do the work yourself? I have the engine out and on a proper stand..... Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 10, 2006 Share Posted October 10, 2006 Trust me, I only had it in pieces a few months ago. The only thing there that will leak oil is the crank seal. Other option is the rocker cover and it's dripping down to there. Err there is one other potential source of a leak, the oil pressure relief valve nut O ring. Link to comment Share on other sites More sharing options...
Rob Posted October 11, 2006 Share Posted October 11, 2006 Yeah, and that bit as well. /vbb/images/smilies/bbcode_oops.gif Link to comment Share on other sites More sharing options...
