ABS problem
RobEvans
When I bought my supra the red triangle and yellow ABS light has always been on, the guy assured me he has had it tested and it was the n/s ABS senser and I could get one for £90
Sure enough I got one for £90 and changed it, but still no ABS.
does the ECU need resetting or light turning off before it will work agian? Or could it be another problem?
Thanks
  • 2 years later...
Thanks
I too purchased my supra with the red triangle and yellow ABS lights always on, but the guy i got it from says that the airbag got deployed and he did not replace it, but it has been showing the lights from since then.... I'm thinking if it has no airbag why don't the airbag light come on instead of abs? can anyone help
thanks in advance
  • 2 weeks later...
hey guys, i been poking around the main fuse box in the engine bay and i realized that my 94 supra has 2 fuses marked abs1 and 2, abs one is 60amps and abs2 is 30amps... abs2 is missing and also one of the two pins the fuse slides onto is missing as well... could this be the reason why my abs and red triangle with the ! lights are on?
