supradibbs Posted October 6, 2006 Share Posted October 6, 2006 any plummers on here my boiler wont light just keeps clicking away check that the gas tap is on thats about as much as i know anything i can try???? Link to comment Share on other sites More sharing options...
MaveriK Posted October 6, 2006 Share Posted October 6, 2006 Reset the shit out of it bud, works with mine. Link to comment Share on other sites More sharing options...
supradibbs Posted October 6, 2006 Author Share Posted October 6, 2006 yeah done all that reset it at the wall and on the boiler Link to comment Share on other sites More sharing options...
GLENN STONEHAM Posted October 6, 2006 Share Posted October 6, 2006 hAVE YOU PAID YOUR GAS BILL? What make/ type is it? Link to comment Share on other sites More sharing options...
supradibbs Posted October 6, 2006 Author Share Posted October 6, 2006 its a baxi solo??? 3 40 pf ?????????? Link to comment Share on other sites More sharing options...
terribleturner Posted October 6, 2006 Share Posted October 6, 2006 Wayne you know Lui is a plumber. Give him a bell. Link to comment Share on other sites More sharing options...
supradibbs Posted October 6, 2006 Author Share Posted October 6, 2006 just rang him no answer what i cant under stand is the heat element on top of the emersion heater has had the plug taken off it has a lead running under the floor from the timer looking thing if i had this at least i could get some f- ing hot water Link to comment Share on other sites More sharing options...
GLENN STONEHAM Posted October 6, 2006 Share Posted October 6, 2006 supradibbs said: its a baxi solo??? 3 40 pf ?????????? Oh shit they"re a bugger to repair!!! um... ONLY JOKING ..... BACK BOILER OR WALL MOUNTED? Does it have a fan? I"m not a plumber so hope someone on here that is will help you.Could be stuck gas valve,dead fan,dirty pilot, igniter brocken/sooted up + loads more depending on type .So many nowadays with different controls/components. Link to comment Share on other sites More sharing options...
Jezz Posted October 6, 2006 Share Posted October 6, 2006 supradibbs said: just rang him no answer Lui just called me. His power steering's gone again so i guess he'll be driving home slowly. Link to comment Share on other sites More sharing options...
terribleturner Posted October 6, 2006 Share Posted October 6, 2006 AGAIN!!!! did the other pump go in?? Link to comment Share on other sites More sharing options...
Jezz Posted October 6, 2006 Share Posted October 6, 2006 terribleturner said: AGAIN!!!! did the other pump go in?? Yep. Thats 3 pumps in 48 hours he's been through! I'm running out of them. My guess is the cap on the pots nakered, or the pots warped during the polishing process and not giving a good enough seal round the cap. Link to comment Share on other sites More sharing options...
supradibbs Posted October 6, 2006 Author Share Posted October 6, 2006 jezzybabes said: Yep. Thats 3 pumps in 48 hours he's been through! I'm running out of them. My guess is the cap on the pots nakered, or the pots warped during the polishing process and not giving a good enough seal round the cap. jeeez whats going on there has someone checked that the feeds are clear??? Link to comment Share on other sites More sharing options...
Pete Posted October 6, 2006 Share Posted October 6, 2006 Anything in the manual ? http://www.baxi.co.uk/products/literature/Baxi-Solo-3PFL.pdf Is there water pressure? If you've not used it a while that may have gone down - it cuts off if it's not high. Bleed rads, top up water until about 1 bar I think? I read up a lot on our combi boiler for common stuff like this. Link to comment Share on other sites More sharing options...
Ewen Posted October 6, 2006 Share Posted October 6, 2006 just scanned through this and I thought you were trying to fix a gas boiler with Supra spare parts. Must concentrate. Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted October 6, 2006 Share Posted October 6, 2006 Ewen Foster said: just scanned through this and I thought you were trying to fix a gas boiler with Supra spare parts. Must concentrate. They are atm Ewen:d The thermo couple is probably fooked and that kicks in a safety feature that will not light the boiler..suana duval one that is:taped: Link to comment Share on other sites More sharing options...
Trig Posted October 6, 2006 Share Posted October 6, 2006 Unlikely a baxi solo is on a pressurised system. Sounds like its got lack of gas or possibly the pilot injector is blocked. You may need to get a gas engineer out mate. I would come down but its miles!! PS there is no thermocouple on a baxi solo 2. Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted October 6, 2006 Share Posted October 6, 2006 Trig said: PS there is no thermocouple on a baxi solo 2. Just chucking what i know in the pot;) Link to comment Share on other sites More sharing options...
Trig Posted October 6, 2006 Share Posted October 6, 2006 No worries dude Do you know what a thermocouple does just out of interest? Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted October 6, 2006 Share Posted October 6, 2006 Trig said: No worries dude Do you know what a thermocouple does just out of interest? And at certain temp shuts the supply off?? had to replace lots of parts on a boiler in my flat..Bet i'm wrong Link to comment Share on other sites More sharing options...
Trig Posted October 6, 2006 Share Posted October 6, 2006 Not bad, good knowledge but it shuts the supply of gas to the gas valve if the pilot goes out. It sends a signal to the gas valve that the pilot is present Link to comment Share on other sites More sharing options...
Pete Posted October 6, 2006 Share Posted October 6, 2006 http://www.diynot.com/forums/viewtopic.php?t=35167 http://www.diynot.com/forums/viewtopic.php?t=11764 http://www.howtomendit.com/answers.php?id=22096 http://cgi.www.a1-gas.co.uk/cgi-bin/www.a1-gas.co.uk/bbmat.cgi?getsubject=1095&script=question&frames=N Lots here - http://cgi.www.a1-gas.co.uk/index.html?http://cgi.www.a1-gas.co.uk/cgi-bin/www.a1-gas.co.uk/bbmat.cgi Link to comment Share on other sites More sharing options...
Mike M Posted October 6, 2006 Share Posted October 6, 2006 Two dissimilar metals giving a potential difference varying with temp. I'll get me coat:d Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted October 6, 2006 Share Posted October 6, 2006 Trig said: nah youre thinking of a boiler stat. good knowledge tho The thermocouple send a signal to the gas valve that the pilot is present Thinking about it now..yeah i'm thinking of the thing that sits on the pipe. and the thermocouple sits in the flame of the pilot to let the boiler know the pilot is on. so keep the gas coming.. My bad:blink: for the pilot light that is.. Link to comment Share on other sites More sharing options...
