bloody boiler help!!!!!
supradibbs
its a baxi solo??? 3 40 pf ??????????
Oh shit they"re a bugger to repair!!!
um...
ONLY JOKING ..... BACK BOILER OR WALL MOUNTED?
Does it have a fan? I"m not a plumber so hope someone on here that is will help you.Could be stuck gas valve,dead fan,dirty pilot, igniter brocken/sooted up + loads more depending on type .So many nowadays with different controls/components.
AGAIN!!!! did the other pump go in??
Yep. Thats 3 pumps in 48 hours he's been through! I'm running out of them. :D My guess is the cap on the pots nakered, or the pots warped during the polishing process and not giving a good enough seal round the cap.
jeeez whats going on there has someone checked that the feeds are clear???
:) just scanned through this and I thought you were trying to fix a gas boiler with Supra spare parts. Must concentrate.
They are atm Ewen:d The thermo couple is probably fooked and that kicks in a safety feature that will not light the boiler..suana duval one that is:taped:
Unlikely a baxi solo is on a pressurised system. Sounds like its got lack of gas or possibly the pilot injector is blocked. You may need to get a gas engineer out mate. I would come down but its miles!! :search:
PS there is no thermocouple on a baxi solo 2.
nah youre thinking of a boiler stat. good knowledge tho :)
The thermocouple send a signal to the gas valve that the pilot is present :cool:
Thinking about it now..yeah i'm thinking of the thing that sits on the pipe. and the thermocouple sits in the flame of the pilot to let the boiler know the pilot is on. so keep the gas coming.. My bad:blink: for the pilot light that is..
