Voo51 Posted October 6, 2006 Share Posted October 6, 2006 Hi Right, I know this have been covered many a time but i have took some pics of the actual boss when modified, well, modified the way i did it!! All i did was cut 45 degree angles from the base of the hole, pics will follow shortly when i get home and upload them. The boss fits perfectly though, and, you cannot really see what has been done unless you look really close. And so, i have just fitted my momo steering wheel boss and wheel perfectly! As i say, pics will be posted in a few hours(providing my steering wheel doent come off on the way home!!) Link to comment Share on other sites More sharing options...
Ian W Posted October 6, 2006 Share Posted October 6, 2006 providing my steering wheel doent come off on the way home!! good luck Vicki Link to comment Share on other sites More sharing options...
Voo51 Posted October 6, 2006 Author Share Posted October 6, 2006 Heres the pics, started by taking the standard steering wheel off as normal(make sure your wheels are straight before you start), then put the boss up against the hub and see roughly where you have to cut, with mine it was 45 degree angles froom the base of the hole where the small stalk comes through. I then cut a metal cutter guy to just cut through the metal, cut the top piece straight off!! Ithen put the boss against the hub, made sure it fit ok, slide the rubber cover over the boss, making sure you get it round the base of the boss(it is a tight fit) then continued to fit steering wheel. Once the boss and wheel is fitted you cannot hardly see where is cut unless your looking for it. Walla, steering wheel!! Also, just incase some members didnt know, the momo boss for the supra also fits the mk2 MR2 momo part 7728. I searched for a mr2 momo boss on ebay and got one for £15. Link to comment Share on other sites More sharing options...
Dragonball Posted October 6, 2006 Share Posted October 6, 2006 Fair enough - I have about 5 of these going to be up for sale! Link to comment Share on other sites More sharing options...
DannyW Posted October 6, 2006 Share Posted October 6, 2006 Fair enough - I have about 5 of these going to be up for sale! How much will these be Paul? Link to comment Share on other sites More sharing options...
Dragonball Posted October 6, 2006 Share Posted October 6, 2006 How much will these be Paul? Will bung them up when I know m8 Link to comment Share on other sites More sharing options...
DannyW Posted October 6, 2006 Share Posted October 6, 2006 Will bung them up when I know m8 Good man, so will they be a modified MR2 boss as above? by that, i mean, are they going to be noticeably cheaper than the supra specific bosses? Link to comment Share on other sites More sharing options...
Voo51 Posted October 6, 2006 Author Share Posted October 6, 2006 the supra boss and mr2 boss is one in the same, you just have to get them cut so they fit perfect, it took the metal cutter literally 2 mins to do, mine was only cheap as i got it off ebay but usually retails at £60 Link to comment Share on other sites More sharing options...
Bob Posted October 6, 2006 Share Posted October 6, 2006 Looking good I'll be fitting mine this weekend - got a HKB / Nardi type boss from an ebay shop for £17 Link to comment Share on other sites More sharing options...
DannyW Posted October 6, 2006 Share Posted October 6, 2006 the supra boss and mr2 boss is one in the same, you just have to get them cut so they fit perfect, it took the metal cutter literally 2 mins to do. Sorry i meant the supra ones that are the best part of a ton and fit with no mods. I might get a cheapo one and do what youve done, looks easy enough from your pics. Link to comment Share on other sites More sharing options...
MR.B Posted October 6, 2006 Share Posted October 6, 2006 Woohoo nice one Vic - looks great! Link to comment Share on other sites More sharing options...
Voo51 Posted October 6, 2006 Author Share Posted October 6, 2006 The momo one i used is the actual momo for a supra mkiv but they dont fit properly, hence the modification, but they also fit the mr2. Thankyou Mr B!!!! Link to comment Share on other sites More sharing options...
Pete Posted October 6, 2006 Share Posted October 6, 2006 It looks like it sits a fair bit further back in that pic - does it? Or is it pretty much the same as OEM? Link to comment Share on other sites More sharing options...
Voo51 Posted October 6, 2006 Author Share Posted October 6, 2006 erm..... im not sure- i cant remember what the oem one was like now..... itmight do actually. itll be at the pod on sundat anyway so if you are going you can look if you wish. Link to comment Share on other sites More sharing options...
supragold Posted October 6, 2006 Share Posted October 6, 2006 Looking good Vic. I might see you up pod Sunday if I get round to going. Link to comment Share on other sites More sharing options...
RobSheffield Posted October 6, 2006 Share Posted October 6, 2006 Link to comment Share on other sites More sharing options...
JohnC Posted October 9, 2006 Share Posted October 9, 2006 Does anyone know where I can get a steering wheel hub which I dont need to modify in order to fit me Supra? I dont know if i'm looking in the wrong places but i can only find momo and isotta ones which aren't direct fits...... Link to comment Share on other sites More sharing options...
