decat or not
mr keef
Hey people,just wandering about the decat thing,at the moment i have a zigen5 zorst and was told by the previous owner the cats ares till there,the car is very very quiet just a little whistle on boost and hey i quite like it,but!!!! been thinking what kinda money would i be looking at to decat and also what kinda power gains do ya get from a decat?oops yea do they sound nice?
sorry but kinda new here
kind regards keef
The decat pipes are approx £120 - £150 each and the second cat is easy to do and can be done on axle stands the first cat is a real pitter to get at.
It also depends if you are J-Spec or UK/US spec, if you are UK/US spec then just remove both and then get some form of boost control and wind it up for some great fun, if you are J-Spec then you either need to leave one cat in or fit a restrictor ring, the latter is better as the cats stop alot of exhaust heat escaping.
:thumbs:
Yesterday I had to fit my mid cat back in to get ready for an up and coming MOT. My boost has dropped around 3 psi.
Normally I run 17 psi on full decat with a resrictor ring, without the ring it creeps up to 20 psi, which I'm not happy running on stock Jap fuel/turbos etc.
It's not so much the drop in boost that effects the performance, it's the way the turbos spool up. I was amazed how just putting one cat back in how sluggish the car feels to full decat.
Speak to Chris Wilson about a restrictor ring if you go full decat, I told him what bar/psi I wanted to run and he got it dead on.
hey keef,
thanks for postage a message in my thread.
but seeing you started one here might as well mention here.
but yea, im in same situation, got a 5 Zigen exhaust.
call me stupid guys (not litterally :p), but how do i know if my car has been decat, or both decatted. :stupid: what are they infact, all i know they are long metal tubes that run across the bottom of the car.
any useful pics will be helpful cheers
Originally posted by cookie
If you remove just one cat will it still pass MOT? and is it worth doing ?
Yes it will pass. I passed with just the front cat in last year.
Yes it is also worth doing, makes the car sound great and will raise your boost up by about 2-3 psi.
As mentioned above you will need an FCD. When I first got my Supra it had only the 1st cat in, it was around summer time, so I was getting away without an FCD, then the winter came and a drop in temperature and I started to hit fuel cut.
