Need some help!
fparrish
Basically my car has been misfiring horribly recently so i have had the plugs and leads done. I have had magnecore competitoon leads fitted and denso iridium plugs. I was hoping this would sort out the problem. Now the car is running nicely in low revs but when you put your foot down it seems to stick for a second at around 4000 rpm, where i lose all power. This is far more noticeable when you take the overdrive off. The car is a 1995 normally aspirated automatic. If anyone has any ideas as to what could be up can you please help?! :search:
Dizzy cap and rotor arm are apparently ok. Have been talking to someone who seems to think could be the inlet manifold? would that create such a problem? If it is say warped or not torqued up properly so as letting air in in another way?!!?
