Jake Posted October 3, 2006 Share Posted October 3, 2006 In Photoshop (ver CS2 if it matters), how can I make an oject have a faded edge? So that it fades to transparent around its border - if you see what I mean. Thanks Quote Link to comment Share on other sites More sharing options...
Pete Posted October 3, 2006 Share Posted October 3, 2006 Yep. Quote Link to comment Share on other sites More sharing options...
Pete Posted October 3, 2006 Share Posted October 3, 2006 You can use various techniques to treat the edges of an effect applied to only part of an image. To leave a distinct edge, simply apply the filter. For a soft edge, feather the edge, and then apply the filter. For a transparent effect, apply the filter, and then use the Fade command to adjust the selection’s blending mode and opacity. .. I can't see how this is useful. Come on Ed. Quote Link to comment Share on other sites More sharing options...
Pete Posted October 3, 2006 Share Posted October 3, 2006 You could apply the concepts in this tutorial perhaps ? Just don't use an elipse, use a stroked path http://graphicssoft.about.com/cs/photoshop/ht/apsvignette.htm Quote Link to comment Share on other sites More sharing options...
Jake Posted October 3, 2006 Author Share Posted October 3, 2006 That'll do it. Cheers Pete Quote Link to comment Share on other sites More sharing options...
China Man Posted October 3, 2006 Share Posted October 3, 2006 open image, choose mask option at the layer window. depends on the mask colour you can use a soft brush and paint the edge away by using black or white colour. if that make any sense? Quote Link to comment Share on other sites More sharing options...
Jake Posted October 3, 2006 Author Share Posted October 3, 2006 Right thanks fellas, got that working now. Another question: When I select an area and press Delete it leaves me with the background colour inside the selected area. I don't want that, I want it completely blank - so that it's transparent. How? Thanks Quote Link to comment Share on other sites More sharing options...
IDO Posted October 4, 2006 Share Posted October 4, 2006 to get it transparent space it has to be on a layer... it will put a background colour in if you are working on the "background" layer... Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted October 4, 2006 Share Posted October 4, 2006 Like IDO says. - Open layers. - Double click background. - Turn to Layer 01 ...delete will remove colour now (You should see a checkered background) Quote Link to comment Share on other sites More sharing options...
