Oil Change Help
Ric
From the battery (bottom right) go up to the power steering reservoir (silver cylinder black plastic top) and then look down into the space between this and the engine block (view from the wing rather than the front bumper) and you should see it fine....
Sump plug can be seen, by looking under the car by the drivers side front wheel. It is a 14mm bolt back from the plastic engine undertray and is angled slightly toward you ie the bolt head is not parallel to the ground
Cheers mate, that's the kind of descriptions I like.... :)
