Hesitation
Jezz
I'm getting a strange hesitation on half throttle between 3k-4k revs. Also sounds like a 'miss' until i accelerate a little harder. Car was running sweet up until last thursday when i put some Bp ultimate in. 10 miles later it started hesitating. Really noticable on the motorway and in 4th and 5th. Car is Bpu with blitz access ems. Any ideas?:search:
Its been raining a lot lately. My bet is the underground tank in the petrol station has probably got water in it, so you've bought petrol & water mix.
I once had this in a Mini. Pulled the choke out to richen the mixture and it went away. More fuel = problem solved.
Probably doesn't do it at low throttle as the ECU is running off the lambda sensor so corrects the mixture to run richer and gets more fuel in to compensate for the water content.
At full throttle you're probably way rich on the fuelling anyway, and the water content will supress any bad effect such as detonation due to going lean (if it does go anywhere near lean, full throttle is very rich on Supes).
That leaves part throttle where the lambda sensor isn't being used to adjust the fuelling quantity, but the mixture is running mid way between stoich and full power rich. The water content is leaning out the mixture too much & quenching the flame (if it fires at all) causing misfire.
Fill up with petrol from another station ASAP & use it up. If it doesn't do it after the next tankfull then it's probably this water problem
If you're worried there may be engine damage take a sample of the fuel as it is now to prove your case against the garage that sold you the fuel. I can have it analysed.
Interesting. Gone through £60 of sainsburys finest and still no difference. Might try draining it all out first.
Hesitation is almost always ignition based IMO.
Check your plugs.
Nice one. I'm on it now. :)
Plugs are brand new. Only fitted the other week. The slight hesitation has now turned into a full on missfire and loss of power under acceleration. I get the 'pops' when turbo 2 comes on boost all the way to the redline. Darn it! Really wanted a run on sunday too. :(
coil pack issue,or connectors?
sounds like the same problem as mine.....although the plugs a new you should always check the gapping on them before you put them in as they may not be correct....
mine were brand new (hks) and 2 of them had different gapping to the rest...sorted the gapping out and it sorted my problem out....
Bingo! Just checked all my coil packs, one plug is completely disintergrated and another wasnt far off being screwed. Got rid of all the crap plastic, slid the pins onto the connectors and filled the plug with silicone. Now running beautifully again. :D Cheers guys. ;) Are coil pack connectors a common issue? Looks like they disintergrate with thew heat. :search:
yes the coil pack connectors are a common fault with a lot of heat getting to then they become brittle and start making a bad connection.
